Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Technical Forums > Forced Induction
Reload this Page >
Suggestions Needed: B18C Turbo: How/where to place water cooling lines?
Old 02-26-2019, 08:57 PM
  #26
Moderator
TheShodan's Avatar
Default Re: Suggestions Needed: B18C Turbo: How/where to place water cooling lines?
Originally Posted by Txdragon View Post
Good luck with this. Best I have found is that it **may** be a 3/8 coarse thread. My intention is to take the drain plug to the hardware store and see if I can find ANY possible threaded nipple fittings and see which works out. If you get one small enough, similar to a small heater core nipple, this could suffice for a turbo drain provided it threads in ok and doesn't leak from the bung. Just attach drain line and clamp that sucker down with a clamp or 2. Done and done.
What Shodan was saying is that since you can't, or IF you can't find a solution, get a radiator that has this option available. It was mentioned that Go-Autoworks sells one, and it is reasonable in price too! Upgraded radiator with the amenities you need for an affordable cost? Sold!!
Correct, my apprentice... I tend to skip the nonsense, and answer the question before it's even asked
TheShodan is offline
Old 03-02-2019, 01:46 PM
  #27
Txdragon's Avatar
I may have solved a mystery here after near a full day search to auto parts and hardware stores. 1 place out of 9, took the time to really help figure this out. The thread pitch of the Honda radiator drain is M14x2.0. I searched online and found a barbed fitting with this pitch. Ordered, and should know in a couple days if it fits or will be a bust.
Txdragon is online now
Old 03-09-2019, 04:43 PM
  #28
Did the fitting work, Txdragon?
0ptimus prime is offline
Old 03-09-2019, 05:01 PM
  #29
Txdragon's Avatar
The threads fit nicely! My only concern is the bit of weep hole.. I'll have to snap a pic but.. I don't have any coolant in my radiator just yet, so not sure.
Old 03-12-2019, 10:45 PM
  #30
Cole D's Avatar
Man, that is awesome. Hopefully this work. For my setup I decided to modify one of those joint pipe sensor adapters to accept M12x1.25 to -6 an fitting in both the upper and lower radiator hose for water lines.
Cole D is online now
Old 03-22-2019, 07:53 PM
  #31
Have you been able to test this out yet? I'm thinking of giving it a try as well since I'll be running an OEM full sized dc2 radiator.
Old 03-23-2019, 10:58 AM
  #32
Txdragon's Avatar
I've been SUPER busy with stuff around the house. Just finished the roof and put up a carport, tore down an old shed. Lots of crap. All I'd have to do is run some water in the radiator to see if it's going to leak. It **looks** like it might, but I may have a solution in case it does. Hang tight, maybe another day. Hopes of trying it today..
Old 03-24-2019, 07:23 AM
  #33
Txdragon's Avatar
Ok so.. I didn't think about it at first, but the little weep hole pictured below will leak like a champ with that nipple. That spot can be sealed with epoxy or a plastic weld gun. Plastic weld kit will set ya back about 25 dollars, JB weld is cheaper but I'd be worried about pressure. The hard part was finding a fitting that would fit the threads. Simple enough if you just CAN'T get a radiator or just keeping costs to a minimum.
Old 03-24-2019, 01:30 PM
  #34
Balor_Gr's Avatar
What about a narrow hole shim with a thick o-ring before the shim?
Balor_Gr is offline
Old 03-24-2019, 01:32 PM
  #35
Txdragon's Avatar
possible. Got an example of what you're talking about?
philcivicjordan
11-04-2015 05:50 PM
slammedobd1teg
07-08-2010 07:31 AM
chrisfromsrq
10-02-2009 08:24 AM
dkboyny11
11-08-2008 08:29 AM
Geauxkart
09-06-2005 06:05 PM
Quick Reply: Suggestions Needed: B18C Turbo: How/where to place water cooling lines?
  • Ask a Question
Question Title:
Description:
