Suggestions Needed: B18C Turbo: How/where to place water cooling lines?
Sup guys and gals.
I've look all over and found multiple answers on best place to run the turbo cooling lines.
I have a b18c gsr with garrett gt35r and I'm still mind boggled on where to run the lines. Any positive info will help. THanks and happy boosting
Moderator
re: Suggestions Needed: B18C Turbo: How/where to place water cooling lines?
This took 2 seconds on Google. don't use the H-T search engine.
https://honda-tech.com/forums/forced...t-way-3024177/
Good luck.
Good luck.
Like "TheShodan" said you should do some more searching first. However I ran into the similar question for my turbo setup as well.
On the front of your block is a allen head plug - remove that - you can buy a plug with a AN male fitting on it. This will be your feed line - goes to one side of turbo. Now for the return - typically ran into the radiator. Go-Autoworks sells a radiator with a AN bung welded to the side of it. That can be your return..... otherwise you can run into the drain plug of the radiator but thats no fun.
I just bought one of those radiators from Go-Auto for my car. Very, very nice piece, I got the triple core and opted for the coolant return bung to be put on the front of the rad instead of the side so I have room for my AC condenser.
Yep^ This is the same one I got but with the bung on the side.... No A/C for me
Re: Suggestions Needed: B18C Turbo: How/where to place water cooling lines?
B&R makes a great kit GT Turbo Coolant Kit which a bunch of us here use. You can also piece together the parts yourself - the block coolant fitting you can buy online for from some place like full-race https://www.full-race.com/store/fabr...olant-adapter/
The other option is to use the coolant line that goes to the IACV but its a lot messier and complicated.
A factory turbo car I owned had a line to the block and the other to the heater core. maybe run it like that.
When hooking up the cooling lines to the front block plug and bottom of the radiator.. Does anyone knows what direction the water flows through the turbo?
Stock water pump pulls water from the block and pushes it to the head.. Block should be low pressure side of the turbo and bottom of the rad should be a higher pressure and feed the turbo.. That means that the radiator is bypassed and would explain why some people are having cooling issues with turbos.. You want the flow to be the other way around so the radiator takes care of the heat the turbo creates. Maybe that is how it works.. I am not sure though.
Moderator
You have it backward. The block port on the front of a b-series is the feed, it goes into the turbo into the bottom port (if there is a top and bottom port), and out the top port to the radiator return (top or bottom). The radiator isn't pressured unless something is wrong or you're boiling over.
If you have flow.. You have a low pressure zone and a high pressure zone.. That is just the way it is.. And there is flow through the radiator.. I have a small flow indicator I am tempted to hook up and verify.
Fair enough. I more meant that if you opened the radiator cap and coolant gushes out type of pressure.
All you need to know is that convection currents draw water through the turbo center section. As Mac has already stated you just need 2 different sources to plumb the water to. How you go about it is up to you. You can simply tee into the water lines at the throttle body or buy the fittings for the front of the block or buy the radiators with the fitting pre welded or buy a fitting that replaces the drain plug on the radiator.
Hey guys. I am about to do my turbo install and ran into this question as well. Right now I have the inlet and outlet water ports for the IAVC plugged: the port on the intake manifold and the corresponding port on the water pipe (B18C5). Can I use these two ports as the feed and return sources for the turbo water cooling setup? I want to avoid welding a bung onto the bottom of the radiator. Thanks in advance!
Moderator
Thanks for the confirmation. So I went through my turbo kit (I haven't installed it yet) and I just noticed that it came with a water line kit using AN fittings. With most of the pieces in place from this kit, it sounds a lot easier and cleaner to use the block fitting and an adapter on the bottom of the radiator. Now I'm considering using a run on swivel fitting to provide two 6AN flares to route an additional line to the wastegate water port then back into the bottom radiator. Would this reduce the cooling efficiency on the turbo cartridge? Thoughts on this?
The schema looks something like this:
Block Adapter --> Swivel on Run Fitting ---\------>Turbo ----------> Swivel on Run Fitting ---> Bottom Radiator
.................................................. ..........\------> Wastegate ----^
There's no need to run water through the gate unless you are under some heavy duty racing app where the gate is seeing extreme heat and long duration open activity. Outside of that, just leave the gate water ports open for air to circulate through it. (The gate is also -4 where the turbo water lines are typically going to be -6)
Moderator
What size fitting do you need for the stock radiator for a -6 waterline hook-up?
Thanks for commenting but that does not answer my questions. For right now I'm running what I have and deciding what efficient radiator to run.
What Shodan was saying is that since you can't, or IF you can't find a solution, get a radiator that has this option available. It was mentioned that Go-Autoworks sells one, and it is reasonable in price too! Upgraded radiator with the amenities you need for an affordable cost? Sold!!
