Suggested total timing on c5 @ 8psi
B18c5, 60-1, pump gas 92, intercooled on Uberdata...blah..blah..etc
What is the suggested total timing to run at 8psi. Internally stock. Im comming up w/ 18 on low cam >3500, and 20 on the high cam.
Engine being WB tuned to high 11's a/f.
Looking for first hand exp. here.
TIA
Modified by hulkhb at 11:15 AM 3/28/2004
TIA
Re: Suggested total timing on c5 @ 8psi (ShowTymers619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShowTymers619 »</TD></TR><TR><TD CLASS="quote">isnt it 16 on stock..?</TD></TR></TABLE>
Thanks, but this is on Uberdata. Im setting the maps not the dizzy.
Re: (hulkhb)
i'm running a jdmb18c wich has similar compression numbers (10.6). i am running 20* total timing @ 10psi and 300 whp. so i would say to stick with about 20 @ 8psi unless you have a good knock detector or you can dyno it.
B2FiNiTY
11
05-03-2004 10:21 PM
X2BOARD
10
04-08-2004 05:18 AM
