studs question for manifold..
ok i using studs instead of bolts for my turbo mani and so i went and paid like $2.80/ea for them at acura. http://images.honda-tech.com/set1//smile/emcrook.gif
anyway, before i put them in do i need to do anything (i.e. put threadlock) to the side that goes into the head, or do i just screw them in? thanks |
Re: studs question for manifold.. (TurbothisLS)
just run them in and make sure they are tight, use the 2 bolt trick, im sure you allready know that.
Rob |
Re: studs question for manifold.. (rjardy)
2 bolt trick?
i know i may seem smart... https://honda-tech.com/forums/images...s/emsmilep.gif but please explain. |
I think he means double nutting. Put two nuts on the end of the stud and tighten them together. Then use the outer nut to torque the stud in. Use the inner nut to pull them out.
Re: studs question for manifold.. (JMinSi2000)
ohh
cool, i'll try it does anyone know if the stud will stop at some point? |
ok i using studs instead of bolts for my turbo mani and so i went and paid like $2.80/ea for them at acura |
Re: studs question for manifold.. (JV)
yeah i still have the packaging.
i'll check and post when i get home. |
yeah i still have the packaging. i'll check and post when i get home. |
| All times are GMT -8. The time now is 07:14 PM. |
