streetimports FMIC for 300+whp d16?
1 Post
So im looking for a FMIC for my d16z6 turbo setup. which will consist of:
-maybe a fully built bottom end
-fullrace copy mani
-sc50 .48 a/r
-2.5 charge pipes
would the streetimports FMIC size 22x9x3 be sufficient for the HP im looking for? I want something better, quality wise at around the same size. but if i go with this IC, dsm bov, custom charge pipes i might be able to sleeve my block.
anyone know if these units are decent? i have searched, i only found 1 person with real feedback but that was for a much larger IC.
thanks!
-fullrace copy mani
-sc50 .48 a/r
-2.5 charge pipes
thanks!
1 Post
Re: streetimports FMIC for 300+whp d16? (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">he rated that intercooler to support about 500hp so it should be enough</TD></TR></TABLE>
i know that. but im also wondering about its cooling capabilities. and if its a quality unit, all the other parts im using have been tested and i am sure about them.
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: streetimports FMIC for 300+whp d16? (kabaroo)
pick up a used DRAG III FMIC for around $200, good for 400whp
I love mine
I love mine
1 Post
Re: streetimports FMIC for 300+whp d16? (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">pick up a used DRAG III FMIC for around $200, good for 400whp
I love mine </TD></TR></TABLE>
really? i thought it was way less than that?
what are the inlet/outlet size?
thanks
i just search the F/I classifieds and pmed a bunch of people.
thanks
1 Post
ugh, 2" seems like its way too small.... i wantes a 2.5 inche piping all the way around
im having such a hard time find thr right IC..... fock
i even found one in minnesota!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kabaroo »</TD></TR><TR><TD CLASS="quote">ugh, 2" seems like its way too small.... i wantes a 2.5 inche piping all the way around
i even found one in minnesota!</TD></TR></TABLE>
Stop focusing on numbers dude. 2.5" is overkill for your goals, period.
Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">the end tanks are 1/2" thick cast pieces of heat sink crap and the tubes have no turbulators inside. weak </TD></TR></TABLE>
Agreed. The cores blow ***.
I was one of the first ones to get one, just because it was so inexpensive.
I logged a few runs when I dyno'd and at 12psi my IACs didn't change very much.
went up only about 5 degrees from ambient, but I'm not so sure how its gonna do at high boost.
i made 220whp on a dynapack at 14psi with the street import ic. its in the link in my sig. I just sold everything though and i'm probably going to go with a pwr ic for my next setup.
Re: (pip9)
I love mine
2"/2.25" I think.
My buddy made 400.2whp with it.
Dont lissen to this dumb ****. If you plan on building do it right the first time go 2 1/2.
your buddy did not make 400whp with 2 inch shut up, and if he did than he is limmiting himself alot. Oh that is right bitch I am back...
Re: (b16psi1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16psi1 »</TD></TR><TR><TD CLASS="quote">
your buddy did not make 400whp with 2 inch shut up, and if he did than he is limmiting himself alot. Oh that is right bitch I am back...</TD></TR></TABLE>
You do know the hot side pipe is 2" on pretty much every turbo kit right?
Re: (b16psi1)
I love mine
2"/2.25" I think.
You can't even use the quote button right.
Welcome back. Too bad you won't last long, again.
I love mine
2"/2.25" I think.
