Stock sleeve HP records
I just had an idea, lets see who's got the max HP on stock sleeves for all the Honda motors out there. Partly 'cause Sleeves are $$$, and partly because they effectivly eliminate any HP limitations. There could also be a sub-group for stock internals motors.
Post:
Engine (D16A6, B18C1, etc...)
Rods
Pistons
Pins, blockguard, etc..
Horsepower
Torque
anything else that you think may be relevent.
If you think this thread is a good idea, keep it at the top
Post:
Rods
Pistons
Horsepower
Torque
Just to get things started..
Jeff Evans ( Boosted Hybrid ) got
355 hp
240 ft/lbs tq
Stock internals b18c1 @ 11 psi
Im sure there is a lot higher too, i just cant remember whose cars did it here on HT..
355 hp
240 ft/lbs tq
Re: (IntegracinGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegracinGSR »</TD></TR><TR><TD CLASS="quote">Just to get things started..
355 hp
240 ft/lbs tq
Im sure there is a lot higher too, i just cant remember whose cars did it here on HT..</TD></TR></TABLE>
To add to that you should check out what Jeff said about stock sleeves here...
http://www.boosted-hybrid.com/viewtopic.php?t=133
355 hp
240 ft/lbs tq
Re: (Mpir3)
520 whp 390 tq stock sleeve B16 block / GSR head
edit: more stuff
Probe pistons and wrist pins
Eagle H-beam rods
Our shop porting on the head
that's it
Brian
edit: more stuff
Eagle H-beam rods
that's it
Brian
Re: (IntegracinGSR)
355 hp
240 ft/lbs tq
Not to get off topic, but how do these people pull such good number from low boost?
Thats 100whp more then mine made at 1psi lower.
I know tuning vary's but 100whp? geeze
Btw I think it's awesome that he's made that kind of power.
355 hp
240 ft/lbs tq
Re: (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid »</TD></TR><TR><TD CLASS="quote">
Btw I think it's awesome that he's made that kind of power.</TD></TR></TABLE>
Well you have a smaller displacement engine according to your sig. It also depends alot on what turbo you are using.
Re: (RyanCivic2000)
Ryan is right.. you have less displacement.. and it does depend on the turbo, Jeff has a t3/t67 to achieve his goal, what turbo are you using?
Moderator in Chief
Re: (b16ahybrid)
Not to get off topic, but how do these people pull such good number from low boost?</TD></TR></TABLE>
Its called a big ******* turbo.
Re: (ITSTOCK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSTOCK »</TD></TR><TR><TD CLASS="quote">How about some d series #'s?</TD></TR></TABLE>
ARFab made 395hp 360tq-->https://honda-tech.com/zerothread?id=692881
and you'll see on that thread that ZexMan made 418hp on stock sleeves
Guest
Posts: n/a
Re: (D-Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man »</TD></TR><TR><TD CLASS="quote">
and you'll see on that thread that ZexMan made 418hp on stock sleeves</TD></TR></TABLE>
correct me if im wrong...but zexman made that number on boost alone, isn't he over 500whp with nitrous?
Re: (IntegracinGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegracinGSR »</TD></TR><TR><TD CLASS="quote">Ryan is right.. you have less displacement.. and it does depend on the turbo, Jeff has a t3/t67 to achieve his goal, what turbo are you using?</TD></TR></TABLE>
T3T4Oe .57 trim .63 AR
Re: (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">
Well you have a smaller displacement engine according to your sig. It also depends alot on what turbo you are using.</TD></TR></TABLE>
I missed that part, I was thinking b16....still I'm jealous
Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 »</TD></TR><TR><TD CLASS="quote">
correct me if im wrong...but zexman made that number on boost alone, isn't he over 500whp with nitrous?</TD></TR></TABLE>
I'm pretty sure it was boost and nitrous to make 418whp and the over 500whp is his new set-up.
Re: (Muckman)
Not to get off topic, but how do these people pull such good number from low boost? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">
Its called a big ******* turbo. </TD></TR></TABLE>
Haha.. Funny and SO true
Re: (D-Man)
Do you know what A/R ARFab was using with that SC50?
Re: (st00pid)
My car made 435/315 ...SC60/550cc inj on stock sleeves with pistons and rods only ---^jason(stOOpid) can vouch for that, he's seen my car at carboy. When I get my car back on the road in a few weeks with the new turbo/manifold/inj's, It will go over 550hp on stock sleeves!!!!
***maybe Jason can set me up with a sweet hondata deal??? So many people have been busting 500 with hondata, now I want one!!!!!!!!!!
Re: (dmecarboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dmecarboy »</TD></TR><TR><TD CLASS="quote"> My car made 435/315 ...SC60/550cc inj on stock sleeves with pistons and rods only ---^jason(stOOpid) can vouch for that, he's seen my car at carboy. When I get my car back on the road in a few weeks with the new turbo/manifold/inj's, It will go over 550hp on stock sleeves!!!!
***maybe Jason can set me up with a sweet hondata deal??? So many people have been busting 500 with hondata, now I want one!!!!!!!!!!</TD></TR></TABLE>
Nice numbers!! What engine is that?
