stock motor mount and 300+hp???
hi i have a dc2 i dynod at 360hp and 295tq,and i have stock motor mounts and was wondering if its worth upgrading mounts,i know it will benefit because my motor flex's alot now when i hit boost,but i dont have the money now but does it help alot to upgrade mounts????
Re: (FONK)
My b16 isn't boosted yet but I just finished window welding the torque mounts.
I'm going to leave the other mounts alone because i don't want the engine to vibrate the chassis so much that my teeth fall out of my skull.
I'd recommend window welding the torque mounts like I did, and possibly an engine damper.
Re: (_gurusan_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _gurusan_ »</TD></TR><TR><TD CLASS="quote">My b16 isn't boosted yet but I just finished window welding the torque mounts.
I'd recommend window welding the torque mounts like I did, and possibly an engine damper . </TD></TR></TABLE>
Window welding? Want to expand what this mean?
Re: (synik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik »</TD></TR><TR><TD CLASS="quote">
Window welding? Want to expand what this mean? </TD></TR></TABLE>
x2
x2
Re: (TurboCoop)
I use urathane.. I got it at an autoglass/glass dealer. exact same stuff that holds your windshild in!! i wouldnt use anything else.
make sure you wear gloves.
Re: (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 »</TD></TR><TR><TD CLASS="quote">I use urathane.. I got it at an autoglass/glass dealer. exact same stuff that holds your windshild in!! i wouldnt use anything else.
make sure you wear gloves. </TD></TR></TABLE>
which is the same stuff as 3M brand Window Weld
Re: (2point2)
Does this significantly help your mounts? And does it vibrate your whole car! like the urethane inserts? Or does it keep the stock feel?
Be great alternative to remove my inserts.
Re: (synik)
You just buy some 3m window weld and fill in the holes on your stock torque mounts.
It feels just like stock, maybe it vibrates a little more..but i can't even tell, and my whole front end feels tighter.
I just did the 2 torque mounts (a/c and tranny)...the other motor mounts would probably vibrate a ton.
Re: (_gurusan_)
Jeez....just spend the $20 bucks and buy the ES Motor Mount inserts. I daily drive my EG with inserts, stiff springs and soon all stiff bushings too, its not that bad with the vibrations..............wussies.....
Re: stock motor mount and 300+hp??? (FONK)
i have a front engine mount replacement (timing belt side mount) urethane mount in my EK
IT RATTLES LIKE A BOX BUT THE CAR FEELS SO GOOD WITH IT!
really helped on wheelhop (more so imho than my ebay traction bars)
i also have ES bushiungs, but only installed the AC side one (my car has no ac tho)
Re: (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">Jeez....just spend the $20 bucks and buy the ES Motor Mount inserts. I daily drive my EG with inserts, stiff springs and soon all stiff bushings too, its not that bad with the vibrations..............wussies.....</TD></TR></TABLE> Vibrations are not bad at all, until a few weeks later. Something starts to rattle. Then something else joins in with the rattling. Until finally your whole car is one loud chorus of rattles that overpowers your stereo system and drives you crazy (on a good day)
Re: (ProjectDarkBlack)
I bought the full urethane motor mount kit, all 5 of em, and the tourque mount ones are falling out already so I think I will try the window stuff, and the DS one (97 Civic) is pretty shitty looking. I havent had a chance to put in the other 2 cause its a pain in teh *** and Im lazy I need some traction bars. My car wheel hops like a bitch
ek-g6
09-18-2007 01:40 PM
Drew Peacock
12-03-2004 03:31 PM
