stock ls vtec with 75shot dyno
stock internal, but full bolt on.
victor x mani
ram air intake
dc header
3" straight through exhaust
650cc injectors
walbro fuel pump
Nos sniper 75 shot wet kit
tuned by morris.
all motor it made 167whp 138wtq
75 shot it made 236.5whp 227.87wtq
victor x mani
ram air intake
dc header
650cc injectors
walbro fuel pump
tuned by morris.
Who is Mr Robot?
Re: stock ls vtec with 75shot dyno
Well the jets are only estimated power gains. It depends a lot on motor health, fuel quality, nitrous pressure, nozzle/jet style and location, and the most important thing of all.... The tune.
Its known as a Direct WHP adder for a reason.
food for through, 69.5 from a 75 shot setup is excellent.
I have seen where 125 shot only net some people about 80+hp (probably being very conservative). There are a lot of variable involved and the anti nitrous folks will never understand.
Good job
ps what is you afr during nitous??
what chassis is this in?
track that f...ing beast and bring back some 11.xx time slips.
It's like turbo and psi, someone using the same turbo, same setup, but make diff power at different psi. And like DDtech said, that's great power for the shot. I've never seen anyone gain the EXACT amount the shot said.
Anything bigger then a 125 single fogger, becomes hard to control. That first cyl gets alot of nitrous. I was on a 100 single wet fogger for a while, once i realized the car would do what i wanted it to, i got rid of it, and went to direct port. That cyl 4 gets a fuckton of nitrous...literally.
On pump gas, the general rule is 2 degrees per 50 and thats fairly safe from the cars i've tuned and had experince with.. on race gas, its really how the plugs talk to you.
AFR's should be the same as a NA car. Running rich on nitrous, is worst then running lean, Seriously.
KHAN SHOP
04-01-2007 12:28 AM
