Stock injectors with turbo - what fuel compenents do I need?
Well since the DSM 450s will fry my ECU I'm not going to use them. I will sell all for of them for 50 bucks if anyone wants them. Anyway, with the stock one's back in, will just an adjustable fuel pressure regulator work? Or do I need the 12:1 FMU? I would rather spend 70 on the FPR if I dont need the FMU.. I will only be boosting 7psi...
[Modified by OKSolSi, 5:46 AM 5/14/2002]
Re: Stock injectors with turbo - what fuel compenents do I need? (OKSolSi)
In a bill lumberg voice. "umm yeah. I think you might need to do a liiitle more research before you turbo. yeahh. That would be great." But yes you need a good inline pump with the fmu. contact turbointeg95@aol.com for a bosch pump.
Re: Stock injectors with turbo - what fuel compenents do I need? (Arturbo)
I am only using at intank GSX pump and the 12:1 and it is working great for me. But, Im only at 5 lbs.
Guest
Posts: n/a
Re: Stock injectors with turbo - what fuel compenents do I need? (SlowB16)
I have my inategra LS in tank pump plus an in line pump for my 12-1 FMU. This is the way I did my set-up for fuel management and I ahve an S-AFC to fine tune things a little moe on the dyno.
I'll sell you my Airtex in-line pump that came with my DRAG kit. Its brand new in the box never used.
Re: Stock injectors with turbo - what fuel compenents do I need? (blackteg)
Why will the DSM 450cc injectors "fry" your ECU? Don't you have a resistor pack for them?
Re: Stock injectors with turbo - what fuel compenents do I need? (VTC_CiViC)
Yeah, thats what I was about to ask too.....why do you think the DSM's will fry your ECU (you do know about the resistor pack, right)?
But as far as a pump in concerned, apparently there has been some hoopla about the TT Supra pump pushing 255lph and being a direct stock replacement (there has been verification by a board member).
The Bosch, though, is a good unit (as has been presented by EnDyn) but seems to take a little work to get the intank version to fit. Nothing major....here is the link to the article on there site: Bosch Fuel Pump Installation
[Modified by EE_Chris, 6:31 PM 5/14/2002]
New User
OkSolSi you should keep the DSM 450s and get a resistor pack, then you'll be set!
-Xerxes
Re: Stock injectors with turbo - what fuel compenents do I need? (turboorangecx)
Even if I did get the resistor pack and kept the 450s, how would I control the flow? I would have to get an FMU anyway right? So why not just get one and keep my stock injectors?
http://www.thedropshop.tv/vafc.htm
keep the 450's.
it will be much better and the pressure will be lower than with stock injectors and an fmu
KevronsEG
08-05-2002 08:29 PM
