Stock axles on 400hp, that bad????
Could a stock axles handle 400hp on 20psi turbo acura 95 b18b w/o any prob.. I'm on a slim on cash so could anyone give me any advice what can i do for my axles??? Or any good website to buy axles???
Banned
Re: Stock axles on 400hp, that bad???? (Turbo-Honda)
.... SNAP!!!!
if your baby it... which you won't do, they'll be fine... but if you plan on launchin at all, they will go
hp won't kill them.... wheel hop will
Re: Stock axles on 400hp, that bad???? (Irishweird00)
hmmm, I'm going to the track in 3 days and doing alot of launching. Do you think it will be ok. I'm affraid if I busted it, it will ruin my day at the track..
If i'm going on a strait line, you said it could hold up right???
Banned
Like I said, wheel hop will snap any axle... If you baby it off the line, im sure it will be fine.... but if you launch hard, they will snap like twigs
what track are you going to? I wasnt aware of anything opening this early in the season... well in upstate at least
im at about 400hp and have stock axles when im on 22in slicks im fine but just today when i was at the track i tryed my friends 24in slicks and i brock an axles on the first launch and spent the rest of the day getting a new one and when i got it fixed i got in the staging lane right when they closed so it ruined my day
Re: Stock axles on 400hp, that bad???? (15psi of fun)
Yeah...i bet those ruin your day haa.. I'm hoping i'm not in the same route. I guess it time for 500hp stage 3.
Anyone know any good website for stage 3 axles?? Or good use brand name??
Does the axles any lighter than stock?
What trak are you goin to i didn't know they were open this early up here.
[QUOTE=Turbo-Honda]hmmm, I'm going to the track in 3 days and doing alot of launching.
QUOTE]
QUOTE]
i think a quafe would be a better drive train upgrade it would even out the power so that one axle wouldn't be getting all the force of the launch and it would help you 60ft then after if you need then get the axles.
Re: (Bryson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">I've seen 10s on stock axles.
Its all in the launch... </TD></TR></TABLE>
Courtney (UglyAssCivic) has over 70 passes on his stock axles. He makes 680whp, and has run a best time of 10.34 @ 140.
Bryson is right, its all in the launch and driving style.
liam
liam
Re: (liam821)
So would I be correct in saying that poly motor mounts would help aid in adding life to your stock axles? I dont get any wheel hop after adding the motor mount inserts. Sure the car vibrates like an earthquake for the first 1000 miles.......
Re: Stock axles on 400hp, that bad???? (ek9turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9turbo »</TD></TR><TR><TD CLASS="quote">it dont matter what size slicks u use, if u hook u r gonna snap an axle</TD></TR></TABLE>
Did you read my post above? He was running 25s and didnt break anything. Its all in the launch. There is a number of people on this board running low 10s with stock axles.
liam
liam
Re: Stock axles on 400hp, that bad???? (Double121)
When an axle snaps what parts could it possibly take with it. I have extra axles so its ok if i snap axles but should i build a cage?
Re: Stock axles on 400hp, that bad???? (GForceInteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GForceInteg »</TD></TR><TR><TD CLASS="quote">When an axle snaps what parts could it possibly take with it. I have extra axles so its ok if i snap axles but should i build a cage?</TD></TR></TABLE>
Most of the honda axles that I've seen snap, either blow up the outer CV or the shaft it self.
If the shaft breaks, you could take out suspension parts...but it depends where it breaks. If the outer CV goes, it shouldn't hurt anything. However, I've seen the inner CV go at 70mph and the bearings just killed the inside of the wheel.
I think Liams statement should be good enough for most people...
Re: (Irishweird00)
Here's a question.. if you arent launching and just everyday driving with 300-400whp... would someone be fine? Another thing... wouldnt stronger axles then mean that you would break something in the tranny? Ide rather break axles than trannies!
