STC dbb hunter turbo + db8 gsr = grocery gettin street car build
#501
Re: STC dbb hunter turbo + db8 gsr = grocery gettin street car build
Just testing out a new image hosting sight since photobucket is being so stupid lately. Imgur so far is a million times better. Wish I knew about them a long time ago. Just a heads up if anyone is looking for a better image hosting site...
Edit: never mind I guess Imgur doesn't work right with ht after more searching.
#502
it didnt want to show up until i logged in. Logged in to say it didnt work.
#503
#504
A local performance shop started selling E85 fuel 👍 I picked up 5 gallons today and started retuning the car for E85. I haven't messed with the timing at all yet, but the high cam fuel map needed a 39% increase in fuel to bring afrs back inline with what they were on 92 pump gas. I'm still spraying methanol just because I have it on the car, it will extend my fuel system and keep intake air temps nice and cool. It will be nice to not have to rely on methanol injection to make power safely. I have the aem fail safe setup, but I was always worried about something happening to the system and not spraying that would cause serious engine damage. The car should pick up some power just from switching to E85 alone because ethanol is oxygenated it has greater power potential then other non-oxygenated fuels. You are basically injecting more oxygen with your fuel so there is more power to be had based on that alone, plus I'll probably be able to increase ignition timing slightly as well.
The fuel they get is guaranteed to be at least 85% ethanol. I tested this batch and it came out to be right around 90% ethanol. You can see from the pic of the data log that my injectors are only around 70% injector duty cycle because the methanol injection is still being used. All in all this should make everything much safer at my current boost levels and compression ratio.
#505
but im interested to see the process change and result. Are you changing the pump or lines.
#506
nice man. People have been tellin me to switch to e85 for years. Im just hesistant because of the cost of upgrading the fuel system. And with what ive heard of inconsistancies, even in warmer weather. But, however, we have a gas station here that did sell 110 octane. Id prolly do that before hand.
94boosted, are you concerned about the corrosive effects of the fuel? There's E85 all over Indy and I've thought about running it, but there's no drain bolt on the prelude gas tank and i would hate to be in a spot where you had to run your tank empty so you could store it. Are you just on a single walbro 255?
#507
Thx for the timing map! I'm always curious to see what other ppl engines like.
That's aweaome about the e85. You shouldn't need the meth injection with e85, but if you want extra cooling you could use it as a Water injection kit. You'll probably find out you don't need to spray anything though.
Closest e85 place for me is 35mins away. I've thought about just driving out and filling cans but I'm not there yet. Want to keep my car practical. The moment I get a station in town though, it's on!
#509
Moderator
I find that results vary depending upon the source of the Methanol that you get. Before you start thinking it's God's gift to hyper-knock resistant fuel, check your methanol concentration. It's one of the reasons why I don't want to use Ethanol. I can keep away from gas stations on a regular basis without that stuff. I'm not necessarily hating on E85 (I don't judge people who use it.. far from it). At the same time, I've seen better fuels do a better job without all the need of the extra sensors and other jazz for those few days you turn up the boost pressure and want to resist knock more consistently.
#511
The shop I get the E85 from has an option to buy a whole barrel and they store it there in a temperature controlled environment in a sealed barrel for you. I'm probably going with the barrel option so at least I'll have the same batch for 55 gallons at a time. The fuel they get is guaranteed to be at least 85% ethanol though, so that's good.
as far as the inconsistencies go, a lot of guys run the GM flex fuel sensor and from my understanding it will allow you to adjust timing/ make corrections in real time depending on the ethanol content of the fuel, so a weak batch shouldn't be a huge huge deal.
#512
#513
I hear you it's just that I don't like relying on methanol injection, all it takes is one run of it not spraying and my engine is done for. Remember how many times calidad blew his engine from methanol complications.
I did end up buying pure methanol and mixing it myself with distilled water, definitely cheaper then using that over priced boost juice lol. Although I haven't tried anything other then a 50/50 mix yet. I've been wanting to try E85 for years and now that it actually available to me I'm excited to test it out.
#515
#516
Moderator
As in VP petroleum-based fuels , fuels with higher concentrations of methanol or ethyl-alcohol, or even propane injection. Fuels that have higher BTUs of energy over (E85-E99) "pump gas" ethanol.
You have tip be willing to see others use other fuels operate based upon their ability to burn efficiently with high BTUs, and not just jump on the bandwagons of " 'cuz higher octane". Obviously octane is a major factor, but not the only factor in deciding what fuel is better for the need.
#517
Moderator
1) bisi didn't first make a 91 octane map before going into the progressive staging of how much methanol was being introduced power psi of boost pressure
2) calidad didn't hook his fail safe up properly; he pinched an electrical wire that was supposed to send the fail safe signal to the ECU and didn't realize it until he was actually in boost at 28psi on the street. You're supposed to test that first before going to the dyno..
So, no.. I have complete confidence in these systems..That was user error, and even he had admitted to it. I just wanted to get that straight.
We'll see you more at the gas station filling up the tank more than driving, that's for certain. I remember several of us in a convoy going to a ciruit track / show about 4 hours away. I was soooo sick of pulling over every 130 miles to fill up.
#518
Your methanol is injected pre- throttle body, not injected directly into each cylinder, correct?
How do you verify equal distribution of meth between all 4 cylinders with it coming in pre - throttle body? Seems like cylinder 1 and 4 wouldn't have the same concentration.... or am i thinking of this incorrectly?
#519
#520
Sounds like the meth really needs to be injected on each runner on the intake no? doesn't sound like it would be too hard to drill and tap each runner with its own injector if you were so inclined.
But honestly, with E85 you really dont need to mess with meth =P
#521
Yes it is sprayed pre throttle body and you are absolutely correct they do not get even methanol distribution and it shows on the plugs. #1 gets the most and #4 gets the least, I have to add about 3% fuel to #4, and 2% fuel to #3 in the individual cyclinder fuel trims to even it out a little. After reading a fresh set of plugs shut down at redline the blue timing mark is much more aggressive on 3&4, and 1&2 could easily handle a couple more degrees of timing.
#522
Moderator
Flex fuel fixes that problem.
I'll sick to my 93/meth - VP fuel. For the new build I won't have to switch injectors, change too big fuel lines or worry about "E85 safe" equipment.
Ok, I admit, now I'm starting to throw shade.. Sorry, guys. I'm weak-minded and old-school.
#523
It wasn't me needing to pull over.. It was all the "flex fuel" guys having to refill their tanks that often.. It was annoying.
#524
I decided to go ahead an buy a barrel and bring it home rather then running back and forth to the shop filling jugs at least for the rest summer when I drive the car more. I think I'll have the shop store it for me over winter when I don't really need it. These thing a heavy lol. I used my engine hoist with a chain wrapped around the barrel to lift it then pulled the truck away and lowered it on a pallet. I had an old walbro 255 fuel pump laying around that I rigged together with a rc lipo battery and switch to pump fuel out of the barrel in my 5 gallon jug or I could even pump it straight into the car. This was a fresh never opened barrel and it tested at about 92-93% ethanol.
#525
badass. wish i had ethanol near me
quick question for ya man, im installing arp head studs on my b18b as i type this and im threading the studs into the block and im wondering how much torque you apply to the studs in your engines. some guys say just hand tight but that doesnt seem right to me. i have them at about 5-10lb/ft right now.
