STC dbb hunter turbo + db8 gsr = grocery gettin street car build
#478
Re: STC dbb hunter turbo + db8 gsr = grocery gettin street car build
Based on weight and trap speed a bump over 400whp. It's never been on a dyno, the closest one is about 3 hours away from me. This car is a heavy pig lol.
#479
What I pile of crap this xtd stage 5 clutch is, rated to hold 475 torque.. yeah right lol. I'm getting really good at dropping my transmission though haha.
No more messing around Action Clutch stage 6 2MD inbound 👍
#482
Action stage 6 2MD clutch is in with a resurfaced flywheel. I've been breaking it in easy with a lot of easy in town driving. This clutch has surprisingly smooth engagement for a 6 puck solid disc, well when compared to the xtd clutch at least lol. The clutch pedal feel is significantly stronger too. I'm hoping to get back to the track this weekend.
#483
nice upgrade, I remember disagreeing on your clutch choice at some point. Best of luck to you. looks similar to my exedy stage 2 clucth difference being the exedy is a 3 puck works like a champ after a few hudred miles. might be a bit harsh engagement until broken in
#485
Made it to the track tonight. Had a great time and didn't break anything lol. The track was not prepped well at all, this was just a street legal night and they barely prep the track for these events. $20 for a tech card and you can run heads up all night against anyone, pretty fun. I made 8 passes total and really had to pull power out of the first 2 gears to get traction. Started out running 12s, then high 11s and finally got it dialed in decent and ran back to back 11.53 passes at 124 mph. The 2 best passes bbg was 1st 12psi, 2nd 16psi and 19psi in 3rd and 4th gear. Car is running really good and making decent power ~450whp and the action clutch is awesome too! My parents were there and got some passes on video so I'll try to get those posted up tomorrow. Pretty happy with the car right now 👍
#487
Here are videos of a few of my runs. Not the best quality, but you get the idea.
#489
#490
Wow, you managed to out-launch all of those cars despite being the one with FWD. Impressive runs.
#493
Thanks man it was a blast!
#494
Here's a pic of the high cam ignition map. I'm on 92 octane with methanol injection. It's and AEM kit with progressive controller and a single 500cc nozzle that starts spraying at 5psi and hits full spray at 15psi. Keep in mind this motor is 11.7-1 compression so not a lot of timing is needed. I actually added a couple gallons of 110 race gas before the track for safety sake. I usually run 1 degree less timing then this map above 16psi on the street to keep it happy.
#497
Thanks!
It will hit 16-18psi at about 4000-4200rpm in 4th gear. This turbo is very responsive, it's almost hard to not hit boost just driving around normally. This little hunter turbo is awesome 👍
#498
awesome, that's about what i was expecting for the 1.8. I have the same experience with mine, great little turbo.
#499
Premium Member
Damn dude you destroyed that XTD clutch quick lol. Never seen one fail quite so fast before. The action clutch should treat you a lot better anyway. Car is silly quick for what it is. Very impressive.
#500
Thanks dude! Yeah I at least expected it to last the rest of the summer lol. Everything was adjusted properly too. XTD did however keep their word and sent me a new clutch free of charge. I definitely won't be wasting my time with cheap clutches anymore lol. I'll be selling this one so really I'm not out much, just wasted time swapping clutches.
