Starting car with no radiator attached no coolant...??
Is the above likely to do any damage like warp the block etc.
I did this a couple of times with my just swapped in engine the car was under no real load backed it up 3 feet or so once and gave it a few revs EGTs were really low 'could hold hand outside the turbo no down pipe'.
I notice now I have installed the radiator is bubbles up a lot creates a white bubbly froth but it does go away coolant doesn't appear milky other then the bubbly froth.
I doubt all the air is out of the cooling system is this just the air or am I stuffed.
Re: (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">ive seen people make 1/4 miile passes with no coolant and its fine...i dont think 3ft would hurt</TD></TR></TABLE>
Re: (synik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by synik »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
