ssautochrome manifold, what downpipe?
i have the ssautochrome manifold (dont flame), just wondering what anyone else has used for a downpipe with this manifold? You think that I could just used a Revhard or Drag one and cut it and modify it to make it fit? or should I just buy some pipe and go 100% custom?
Re: ssautochrome manifold, what downpipe? (dunkd)
I believe that they allso make the manifold to go with that manifold. Just a tip, i didnt see the turbo on the mani, you may want to bolt the turbo to the mani outside of the car, much easier that way
Rob
Rob
or you can just buy a flange and ubend and test fit yourself....a marker and a good eye is your friend.....one Ubend can do it if you cut it right...but buy two just in case
Re: ssautochrome manifold, what downpipe? (mamaboy)
I got their downpipe with a D series manifold i bought from them and its not worth it. The finish looks nice and the bends are decent buts its like 2"id. And the flange they gave me for that bolts to the cat in like 2 5/8ths inner diameter. On a side note the welds on mine look a lot better so I think their quality may be getting better, downpipe still sucks though.
why flame???
there's a guy on here that was pushing 14psi with that manifold.
all you have to do is brace the mani, which looks like you have, and find a way to brace the turbo a little. you'll be good to go.
why don't you just use the dp til it starts to go under the car, then cut it from there and put 2.5" piping? this way, you won't have to worry about a muffler shop doing shitty bends from the turbo all the way back to your cat...just a thought
