spraying a 00' SI
we installed a zex kit on a 00' honda SI. it's a single nozzle, WOT kit. we tapped the hole about 4 or 5 inches away from the TB. should we have put it farther away or is that o.k., it seems to pull fairly strong. 55 shot. thanks
Re: spraying a 00' SI (11secdx)
I've read that if you use a dry system, which the zex kit is, that you should put it between 2 and 3 feet away from the throttle body so it'll be able to cool the intake charge better. I may be wrong so anybody else have any ideas.
before i had my turbo i had a zex kit and my nozzle was almost next to the air filter... call zex tech support and ask
Zex™ • 3418 Democrat Road • Memphis • TN • 38118 • US 1-888-817-1008 http://images.zeroforum.com/smile/emthup.gif |
Re: spraying a 00' SI (jdm civic)
i always heard 8'' away from TB
dry shot is garbage anyways http://images.zeroforum.com/smile/emdgust.gif |
Re: spraying a 00' SI (D-SPEED)
no...place it about 6" from the throttle body. You want it AFTER you intake sensor. I've sprayed two different kits on my car.
-ryan |
Re: spraying a 00' SI (riot)
on my accord it is 12" away from the TB
that was my next question. what about the intake sensor.right now its after the sensor. i also heard on the dry kit to move it farther away. after we had already installed it .
| All times are GMT -8. The time now is 03:03 AM. |
