Which spark plugs for my Turbo H22A / H22 - copper or iridium ???
Ok after spending over an hour searching and reading on H-T, tryin to see if I should stick with my old NGK Iridium IX Plugs (ZFR6FIX-11) OR go with NGK Copper (BKR7E-11) for my turbo H22A which puts out like 300Whp, I am still kinda confused which ones to use...
What are you turbo H22/H22A guys using and at what gap setting ?? Thanks Guys!
Re: Which spark plugs for my Turbo H22A / H22 - copper or iridium ??? (pcguy760)
go with the copper. gap is going to be different on every car. start at like .025 and tighten up if you need to.
Re: Which spark plugs for my Turbo H22A / H22 - copper or iridium ??? (Turbo-charged)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">go with the copper. gap is going to be different on every car. start at like .025 and tighten up if you need to.</TD></TR></TABLE>
Okay the car was tuned with a .30 gap on the iridiums...
Okay I am still confused by which sparks plugs to get lol - after spending the whole night searching, I found -
BKR7E / BRK7E-11 - most popular for turbo Hondas but can you guys confirm these work on the turbo H22A without ANY issues??
BKR7EIX - Iridium version of the above plug I guess and apparently stronger and better - do these really give BETTER performance compared to the regular ones??
Also, since I am making like 300Whp do I STILL need a 7 heat range plug or is my current 6 heat range Iridium IX plugs good enough??
Modified by pcguy760 at 9:05 AM 9/18/2008
I have seen the Tips on the Iridium PLugs break off and destroy motors stick with the copper plug
you are WAY over thinking this lol
go buy a set of bkr7e-11's, .030 .025 gap. at your boost and power levels it wont really matter, either gap will be fine.
we stock hundreds of these plugs at a time because we use them so much, including H22's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-charged »</TD></TR><TR><TD CLASS="quote">you are WAY over thinking this lol
we stock hundreds of these plugs at a time because we use them so much, including H22's </TD></TR></TABLE>
yeah I think I am gonna get them since I came across quite a few threads of the iridium breaking off and destroying the cylinder / piston Kinda wierd because you would think a more advanced plug would be better... confusing as always...
i prefer the coppers and they are way cheaper, which is ironic haha
ive never seen an iridium plug cause a problem however.
the only reason i see using an iridium plug is if your EMS needs a resistor plug, which NGK does not make anything with a heat range colder than 7.
however im sure we are all guilty of using a non-resistor plug, and very seldom to you run into any issues with that.
anything making big power we run a r5671a-8, 9, or 10 depending on the car.
Update : WOW, I was surprised today when I put in the copper spark plugs (BKR7E - gapped to .030) and the car ran bad!! I mean I could feel a complete difference in the way it pulled when I got into boost and it was not the same
So I took those out and put the old NGK Iridium IX (also gapped to .030) back and instantly I could feel a difference. Car accelerated so much better and the power was there - I know this is not the first time someone has experienced this but anyway that was my experience!!
I guess the Iridium IX is better - in my case that is...
pcguy760
07-17-2008 10:27 PM
