Sooo I misshifted...and im pretty sure something is ****ed
So im in 3rd at 6000RPM and shift to 4th. But it doesnt go in 4th. It goes in 2nd. 11,000RPM sounds sick but not good for a stock GSR motor.
SO i pull in a parking lot, and its idling real rough. Like its running on 3 cylinders. So I do a spark test, all 4 cylinders are recieving spark. I check the plugs, all of em look fine . Running short on time, I make my way home. Driving is fine, it doesnt hesitate or run rough like it would if an ignition component was fucked up.
Any ideas?
btw car is a boosted stock gsr, tuned with neptune 550 injectors
Any ideas?
Re: Sooo I misshifted...and im pretty sure something is ****ed (vg7z)
If this is the first time you've done it, I wouldn't be TOO worried about it, at least I wouldn't think so. You may have just starved it for oil that one time and once it sits and cools down and you run it again it may be alright, just be careful with it that's all. Anyone else have an opinion?
comp. test is #1 on my to do list tommorow
i drove home for 5 miles and while driving at part throttle it drives normal. but once its in neutral and idling it idles rough, misfiring i beleive.
could i have jumped some timing?
Re: (lightcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx »</TD></TR><TR><TD CLASS="quote">rev limiter doesnt stop a mechanical over rev</TD></TR></TABLE>
Re: (Topdawgg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg »</TD></TR><TR><TD CLASS="quote">rev limiter is there for a reason....</TD></TR></TABLE>I went from 3rd to 2nd the datalog say it went to 12,100rpm broke a can in two pieces bent 8 valve +the crank and the time slip say it was doing 115@ the 1/8
Re: (vg7z)
Most likely a couple bent valves.If you have adjustable cam gears see if they have moved.And yes it is possible that it jumped a tooth also.
Re: Sooo I misshifted...and im pretty sure something is ****ed (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">sounds like you bent some valves
do a compression test... </TD></TR></TABLE>
Agreed
Agreed
all i got to so lang is AHHHHHHHHHHHHHHHHH ****........do the easiest test first vacuum gauge...if you have a boost gauge that can read vacuum do that its easier....or check timing
Re: (ragethemachine86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ragethemachine86 »</TD></TR><TR><TD CLASS="quote">rev limiter doesnt stop a mechanical over rev</TD></TR></TABLE>
lol i thought i put does'nt sorry
i was drunk one day an i had my buddy drive my dialy crx. he miss shifted about....everytime. retarted. bent some valves..nothing big. thats what your problems i bet. 10-1
My friend did this yesterday with his boosted ls. Shifted from 3rd to 2nd at 90mph...thankfully the engine was alright.
Re: Sooo I misshifted...and im pretty sure something is ****ed (Mr Wonderfull)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull »</TD></TR><TR><TD CLASS="quote">valves are fucked
i agree a vac guage would be an indicator of valves being fucked... Id be willing to bet compression test is gonna make ya sad,, shitty, i did the same thing with my boosted f series. got lucky, but nowhere near 11k, 9 i think...lol but it idled fine and comp was still good</TD></TR></TABLE>
compression test done today. 180 180 150 110. ****!!!!!!!!!!!!!!!!!!!!!!!!
i boguht some valves and a headgasket. hopefully the guides arent damaged
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vg7z »</TD></TR><TR><TD CLASS="quote">
i boguht some valves and a headgasket. hopefully the guides arent damaged</TD></TR></TABLE>
Pull off your cylinder head before buying anything, like new valves you possibly might need a new head after you see the damage.
hey homo, so did u geta check the head yet? lemme kno how its goin, if u need help wit ne thing ...hit me up..aiight ******...later....
Re: Sooo I misshifted...and im pretty sure something is ****ed (99vSmEj8)
damn is he a fortune teller, already knew what was fucked before he took it apart?
