solution-oil return?
I recently pulled apart my oil return line setup to start from scratch. However, when I removed the drain flange from the turbo itself, the gasket refused to come off and is sealed onto the turbo. Before I attempt to remove the gasket from the turbo via razor blade, is there any type of sealant I can use between the gasket and the drain flange that will hold and not leak oil? I apologize because these pics are quite big and blurry but anyway, heres what I've got:
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D |
Re: solution-oil return? (highmilehatch)
just leave it on there, no reason to take it off if its just gonnna go back on https://honda-tech.com/forums/images/smilies/emthup.gif , thats what i did, and its still selaed up good https://honda-tech.com/forums/images/smilies/emthup.gif
Re: solution-oil return? (evoeone)
gasket remover or break dust cleaner works
Re: solution-oil return? (94goldjungsr)
why bother taking it off if the oil drain flange is just gonna go back on??? just curious
honda-bond worked good for me.
| All times are GMT -8. The time now is 07:00 AM. |
