SOHC Boosted Set ups! Chime IN...a place for the SINGLE SLAMS
Re: SOHC Boosted Set ups! Chime IN...a place for the SINGLE SLAMS
i know alot of people swear by the autozone axles but each to their own i guess. looks like i might have to email the driveshaft shop
how much power are you running to need better axles though. if you go easy on the shifts and launch you dont need upgraded axles. i think the stock ones hold fine.
hey guys havent been on here for along while. i have a 94 accord ex with a fully built bottom end.
f22b1:
benson sleeved block
bisimoto 9.1:1 (arias) pistons
bisimoto forged h beam rods
arp headstuds
arp main studs
oem oil pump
clevite main bearings
clevite p rod bearings ( race bearings
napier rings
stock cam, springs and valves for now
moroso catch 10an fittings
garrett 70mm turbo. 84 a/r exhaust housing with t4 flangw
percision turbo 1200cc injectors
neptune rtp
hks ssq bov
cx racing 32x11x3 intercooler
2.75 ic piping
38mm wastegate soon to be upgrading to 50mm
im sure im missing more.
near future mods
bisimoto 3.6 cams w/ valvesprings and valves
port and polish job on the head
golden eagle intake manifold
f22b1:
arp headstuds
arp main studs
oem oil pump
napier rings
neptune rtp
hks ssq bov
2.75 ic piping
near future mods
Well coolant system is getting pressurized so either headlift or cracked sleeve....im leaning twoards headlift.
Even so it put down 304whp and you can see the car start bucking and i let out at 6200rpm...i have a 8500 redline.....its easily over 400 for sure....now to fix it, dial in the tune a bit more and put down some respectable numbers
Enjoy
Enjoy
i have nothing concrete yet, just bits and pieces. but the idea is
a D16A6 rebuilt a few thou ago with some sort of forged pistons and rods (no idea, i didn't do the build). GT28RS, Megasquirt 2, Edelbrock manifold and exhaust elbow. CBR ITBs with custom velocity stacks, some fittings and bits.
still loads to do and research; air-to-water, a better clutch, run all the hard lines, fix my damn harness adapter, etc.
Its actually at 25psi ...and even with the h.g. problems im having boost hits hard at 4200rpms per the map i jumped over 125whp in 100rpms! And another 50 when vtec hits....im considering just throwing a new hg at it and redyno as is and see what i really put down
f22b1:
arp headstuds
arp main studs
oem oil pump
napier rings
neptune rtp
hks ssq bov
2.75 ic piping
near future mods
f22b1:
arp headstuds
arp main studs
oem oil pump
napier rings
neptune rtp
hks ssq bov
2.75 ic piping
near future mods
Vitara/Eagles
Stock head
FarmYard tuned
This was my only pass of the year at this power level, had more in it..I was so jacked up for this pass, I didnt ride out first, and short shifted second
A cage, and valve springs are next on the purchase list.
Stock head
FarmYard tuned
has anyone ever tried to upgrade head studs from 10mm to 12mm or 13mm? has anyone reached 300whp @18psi?
more like probably 1000 miles on the bottom end and probably only 150 miles on the head, and the oil being changed 5 times since the bottom end was put togther.lol
by the way here is a pic of my motor setup.
im new to honda tech sorry if im posting in the wrong spot. im building a d16a6 aka zc my goal 300hp d16a6 in 90 civic hatchback. im getting eagle rods and vitatra pistons what does every one think about using these pistons
You will be able to reach that with a stock head and built block. Should be fun in a Ef hatch
hello guys, new here ^.^ i have a stock D16y8. I want to go FI and would like some tips or advice to point me in the right direction. just saving up $$ for the setup.
