sohc 300 - 400whp, what parts besides engine >>
sohc motor.
what else besides engine upgrades are needed.
550cc injectors good enough ?
standard walbro fuel pump upgrade ?
engine mounts ? ( Currently stock with energy suspension inserts )
Axels ? , i know if im lauching all the time stock will break, but what about just for daily drivability.
anything else,
thanks
platinum.
anything else,
thanks
platinum.
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: sohc 300 - 400whp, what parts besides engine >> (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">sohc motor.
anything else,
thanks
platinum.
If I ever do my 350whp SOHC build...
Precision SC50 (.48 a/r)
Lovefab manifold
Tial 38mm
3" downpipe -> 3" cat -> 3" exhaust
Zex 105300 cam (turbo SOHC cam)
Flamenco-T oil feed/return lines
HKS SSQV BOV
ACT XTSS clutch w/street disk
Gator Racing Stage 2 axles
Uberdata w/ 3 bar MAP
Walbro 255lph standard pressure fuel pump
You sure your motor's up to it? I know it's built, but you had problems a while back didn't you? Get those sorted out first.
anything else,
thanks
platinum.
Lovefab manifold
Tial 38mm
HKS SSQV BOV
Re: sohc 300 - 400whp, what parts besides engine >> (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">
yea im doing a full rebuild, and this time getting her sleeved. either benson or AEBS.
not sure yet.
so that walbro upgrade whould be fine then. ?
platinum.
not sure yet.
platinum.
anything else,
thanks
platinum.</TD></TR></TABLE>
I would go with 72lb just to be safe.
I also would run aftermarket axles. I broke two stock ones this summer. One launching the other during massive thrid gear wheel hop.
anything else,
thanks
Stock water and oil pump would be fine. There are some mods you can make to the stock oil pump to make it flow better. I can find the link when I get home.
also over 300whp i would go with a good MSD setup, or something to control ur ingintion timing and what not, Hondata S200 with boost option and a 3 bar
or urberdata or chrome, something on the lines, of a standalone, AEM EMS if ur a baller
Also ur going to need some Tranny work, the shorting gears of a y8 tranny is good, but if u want it to hold up, look into getting carbon coated sinkros and a stage 3 or a 6 puck or 4 puck clutch with a 10 to 12 pound flywhell, gator stage 2 axels should be good
extended studs for mounting slicks is also a great upgrade
Big Front mount Intercooler, for up to 400whp
Mount Mounts, JimFab or Inserts should be alright
u can also look into trackson bars, with that much power, wheel hop is going to happen, i installed my omni power full coilovers and it took some of the wheel hop out of my turbo y7.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 »</TD></TR><TR><TD CLASS="quote">what about
water pump
oil pump
etc..
OEM Honda, brand new.
Get a cam gear.
Fuel Rail (If you want)
BOMB-*** CLUTCH. Def. need that one.
Can't think of anything else you haven't covered.
water pump
oil pump
etc..
Get a cam gear.
Yep, I just picked a quaife lsd, I got through this year with stock dif and stock axles, but I know it wasn't going to last long. And I'm going to be giving Earl a call soon too, benson time.
Re: (ELSpool)
I already have hondata with boost
stage 3 ACT and 8.5 lb flywheel
so stock waterpump and oil pump are fine
is there avantage to run external waterpump. ?
with the diff hold as long as im not launching with slicks.
for the MSD ignition, what is recomended.
thanks for the input guys.
platinum.
platinum.
can you please help me i have a sohc runnin 8lbsi have a greddy kits and im runnin 310 injectors. my prob is that its running too rich and it throws a misfire in all cylinders. ive had the emanage re-programmed twice. any suggestions?anyone? this is so frustrating-2000 civic ex
Re: sohc 300 - 400whp, what parts besides engine >> (shalts13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shalts13 »</TD></TR><TR><TD CLASS="quote">can you please help me i have a sohc runnin 8lbsi have a greddy kits and im runnin 310 injectors. my prob is that its running too rich and it throws a misfire in all cylinders. ive had the emanage re-programmed twice. any suggestions?anyone? this is so frustrating-2000 civic ex</TD></TR></TABLE>
You should start a new thread instead of taking over someone elses.
Get real engine management like a hondata,uberdata or neptune and bring it to a real tuner and that problem will go away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shalts13 »</TD></TR><TR><TD CLASS="quote">do you have any intelligent answers?
KICK ROCKS!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shalts13 »</TD></TR><TR><TD CLASS="quote">You should start a new thread instead of taking over someone elses.</TD></TR></TABLE>
Ditto.
KICK ROCKS!!
Ditto.
OG triple OG
Re: sohc 300 - 400whp, what parts besides engine >> (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman »</TD></TR><TR><TD CLASS="quote">RC has 750cc Saturated. I would get those.</TD></TR></TABLE>
my new injectors
you get your car sorted out yet ladysman?
my new injectors
Re: (platinum00)
stage 3 ACT.</TD></TR></TABLE>
ACT doesn't do stages. what disc and what PP do you have?
OG triple OG
Re: sohc 300 - 400whp, what parts besides engine >> (Hella_JDM)
i just ordered an action 2md clutch for my y8 turbo , looks to be about the highest rated single disc clutch for the d series. cant wait to get that ****** in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">
my new injectors
you get your car sorted out yet ladysman?</TD></TR></TABLE>
Workin on it
http://sohchonda.com/ipw-web/b...=4782
I have the Xtreme 6 puck by ACT since you were talking clutches.
my new injectors
Workin on it
Scracho
08-27-2013 08:39 AM
mr twig
47
05-26-2005 11:21 AM
