Sleeved H22 Eg Turbo Choice SC61?
hey a 95 eg w/ a jdm h22 built. and i want a bigger turbo right now i have t3/t04 but i want a different turbo what do you guys suggest. iw as thinking sc61. but i want the t04. also i probably want a new manifold where can i get a good tubular one?
Re: Sleeved H22 Eg Turbo Choice SC61? (honda13typer)
Well first off, welcome to the board. Now how much hp do you want, and what do you want to run in the 1/4, is this a street car, street/drag or str8 drag?
yea gotta know what you wanna do with the car IE street car or drag car etc. If a street car just keep the t3/t4 and spary it for more poer rather then getting a bigger turbo that will spool slower
Re: (stinger)
go sc61...depending on your power goals...spool isnt bad on an h22...u'll see full boost around 4300rpm..depending on what your max boost setting is...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda13typer »</TD></TR><TR><TD CLASS="quote">hey a 95 eg w/ a jdm h22 built. and i want a bigger turbo right now i have t3/t04 but i want a different turbo what do you guys suggest. iw as thinking sc61. but i want the t04. also i probably want a new manifold where can i get a good tubular one?</TD></TR></TABLE>
http://www.innovativeturbo.com The GT66 DBB will make more HP/Tq and outspool it by around 400rpm's The major downside is the price (unless you don't care), and it's probably the best performance turbo you can buy
Re: Sleeved H22 Eg Turbo Choice SC61? (silversupragirl)
i want a my car to be drag/street but i want to compete in ndra and the only allow 2 power adders which engine swap count as a power adder and turbo is the other. i want between 5-600 on the dyno and hopefully a mid 10. im really leaning toward sc61 but what trim and comressors should i get also can i get it with a ball bearing or does it come with one i heard there is a gt wheel for it.
Re: (stinger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stinger »</TD></TR><TR><TD CLASS="quote">you want a street/drag car and a mid 10 1/4 mile?</TD></TR></TABLE>
sounds like he does...and your point is....?
miracle happened and boost controllers were invented
Re: Sleeved H22 Eg Turbo Choice SC61? (DBallz)
what do guys think 69 or 76 trim on the sc 61 also to4e vs to4s i know the "s" is better but is it worth the extra money. what exactly will it do ie more power faster spool or waht?
Re: (GOLDBERG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG »</TD></TR><TR><TD CLASS="quote">
miracle happened and boost controllers were invented </TD></TR></TABLE>
Really boost controllers what are those? I never knew they had those! Just sayin a 10sec. ride isnt going to be a fun daily driver, but to each his own. I would not want to drive a 10sec DD around IMO
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda13typer »</TD></TR><TR><TD CLASS="quote">i want a my car to be drag/street but i want to compete in ndra and the only allow 2 power adders which engine swap count as a power adder and turbo is the other. i want between 5-600 on the dyno and hopefully a mid 10. im really leaning toward sc61 but what trim and comressors should i get also can i get it with a ball bearing or does it come with one i heard there is a gt wheel for it.</TD></TR></TABLE>
Someone correct me if I'm wrong, but I really don't think that an engine swap is considered a power adder...
meanEG
12-06-2003 10:59 AM
