Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   sleeve (https://honda-tech.com/forums/forced-induction-16/sleeve-364992/)
Oniss Dec 20, 2002 12:17 PM
sleeve
i am not totally decided yet but i am looking into sleeving my cylinders. i know a machine shop here who sleeves cylinders for allot of hondas, nissans and acuras so it's not a problem finding someone to do it. what sleeves (specifically) would you recommend for a 2000 honda civic si with an 81.00mm bore diameter, 9:8:1 compression ratio and a 79.00mm bore 0.57 inch head gasket? thanks!
BudaKai Dec 20, 2002 12:30 PM
Re: sleeve (Oniss)
Not to be a dick, but you just defined Noob to me. Thank you now I know.
It's all up to you. What do you mean has done a lot of sleeving. As in iron replacements or build up type sleeves. There is a big difference between the two.
Oniss Dec 20, 2002 12:51 PM
Re: sleeve (tzsir)
thank you for your friendly reply. iron replacements and build up sleeves.
93LSivic Dec 20, 2002 03:35 PM
Re: sleeve (Oniss)
I'll be doing a Darton groupbuy after the new year. Keep a lookout for it!
