Since day one I have been told to look at WHP not PSI but.....
When I talked to my tuner he told me that since I will be boosting a stock GSR he personally wont tune pass 10psi for relability reasons. I always thought that a stock gsr was good for ~320WHP. My goal is to get over 300WHP for my DD using a
-ramhorn with a 3"DP through a 3" exhaust
-a T3/T4 57trim
-TIAL 38mm WG
-3bar Map sensor
-ARP headstuds
-Hondata IM gasket
-Tuned on S300
-93 octane
I guess I am unclear as to why now PSI is being looked at and since the day I started researching turbo's I have always been told to look at WHP not PSI. Is anything over 10psi too much for a stock GSR and the rings cant take it or what? Thanks for the help.
-a T3/T4 57trim
-TIAL 38mm WG
-3bar Map sensor
-ARP headstuds
-Hondata IM gasket
-Tuned on S300
-93 octane
Interesting, I'd like to know this too since I have a very similar setup with very simialar goals, I'm getting tuned next month
Did you tell him what kind of turbo you had?
Re: Since day one I have been told to look at WHP not PSI but..... (97_coupe)
A. what size is your exhaust side of your turbo?
B. if your unsure of your tuner & don't trust him, get a second opinion from a different tuner!
* bottom line is, your hp still shouldn't exceed 320ish on stock block gsr.
maybe he tune setups like your and he know how much power it will make at 10psi .
wow knows...
wow knows...
psi is important when you know which turbo you will be using...
Re: Since day one I have been told to look at WHP not PSI but..... (Running925)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Running925 »</TD></TR><TR><TD CLASS="quote">A. what size is your exhaust side of your turbo?
Unsure at this time what one I will get, thats why I didn't list it,
I trust the tuner and I would rather have him be conservative than be unrealistic and say that he would tune a stock GSR reliable for 400WHP but I guess I just don't understand the whole 10psi.
Re: (187Chor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 187Chor »</TD></TR><TR><TD CLASS="quote">how can the tuner tell u what psi is safe if you didnt tell him what turbo you are using?
go to another tuner</TD></TR></TABLE>
He did know my setup and thats when he told me 10psi, I'm just figuring that its to cover his own *** by reducing the chance of something happening.
Better off asking him this question yourself and going from there
Re: Since day one I have been told to look at WHP not PSI but..... (alpha)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">Are you sure he wasn't just saying that he won't tune past 10 psi with the stock map sensor? That is where I draw the line now adays on stock sensors, b/c you can utilize a boost cut.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97_coupe »</TD></TR><TR><TD CLASS="quote">
-3bar Map sensor</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alpha »</TD></TR><TR><TD CLASS="quote">Better off asking him this question yourself and going from there </TD></TR></TABLE>
Will do, thanks
Will do, thanks
Re: Since day one I have been told to look at WHP not PSI but..... (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97_coupe »</TD></TR><TR><TD CLASS="quote">When I talked to my tuner he told me that since I will be boosting a stock GSR he personally wont tune pass 10psi for relability reasons. I always thought that a stock gsr was good for ~320WHP. My goal is to get over 300WHP for my DD using a
-a T3/T4 57trim
-TIAL 38mm WG
-3bar Map sensor
-ARP headstuds
-Hondata IM gasket
-Tuned on S300
-93 octane
I could see 10psi getting you close to that 320whp mark.
-a T3/T4 57trim
-TIAL 38mm WG
-3bar Map sensor
-ARP headstuds
-Hondata IM gasket
-Tuned on S300
-93 octane
supraccordlx
Engine Management and Tuning
10
03-22-2009 07:16 AM
dc4g
04-19-2007 05:32 AM
