Should I turbo this bit*&%#ch (175,000 miles)
Old 07-16-2002, 09:23 AM
Charlie Moua's Avatar
Default Should I turbo this bit*&%#ch (175,000 miles)
what do you think? should i do it? will it hold the greddy SOHC 15G turbo at 5.5psi?
I just wanna see if i can get away with it.
Old 07-16-2002, 09:26 AM
PrecisionH23a's Avatar
Default Re: Should I turbo this bit*&%#ch (Charlie)
anything is possible, id buy a new motor though...
Old 07-16-2002, 09:27 AM
CovertFI's Avatar
Default Re: Should I turbo this bit*&%#ch (GudeH23a)
question is do you have enough money if it does not hold?
Old 07-16-2002, 10:48 AM
Default Re: Should I turbo this bit*&%#ch (CovertFI)
yup.... i really want a Bseries motor and the turbo it but... not enough money to do it all a once, so i might as well do SOMTHING WHIS THS CAR. I have a 90 civic si that is mint except for the miles on it and i hardly drive it.... so i might as well mess around with this POS motor and learn something... and it doesnt; really matte if i blow it up or not.
****Is there anyhing i should check first before slaping on the turbo?
Old 07-16-2002, 01:12 PM
#1 Washington Commanders Fan
The GreenD16's Avatar
get the compression tested and then see where that goes
Old 07-16-2002, 01:19 PM
CovertFI's Avatar
Default Re: Should I turbo this bit*&%#ch (GreenD16)
Old 07-16-2002, 01:23 PM
Etylorcen's Avatar
If you eventually wanna go b series then turbo dont turbo yer sohc now because the turbo kit will be useless when you do get a b series. Just get a b20 or b18 for now and you'll enjoy the increase of power until you finally do turbo it.
Old 07-16-2002, 01:25 PM
CovertFI's Avatar
Default Re: Should I turbo this bit*&%#ch (Etylorcen)
you can swap everthing over except the manifold. you might have to bend a pipe here and there, but everthing will work
HellbillY
02-21-2005 07:41 PM
vtec181
01-30-2004 07:31 AM
spider_man02
06-11-2003 10:17 AM
99 HXagon
01-21-2002 10:38 AM
Quick Reply: Should I turbo this bit*&%#ch (175,000 miles)
