Should I Save Up For A Twin Disc Or Not?
So I installed my Jun Fly wheel and noticed that my ACT 6 puck is kinda wearing out and I would need to replace it soon.
My setup is going to be a B16 pushing roughly 330-350whp.
Its either i buy a twin disc or save money and get a normal 6 puck and use the rest of the money to get a Kaaz LSD and ATS Final Drive.
And if you do suggest either twin disc which ones should i look into, and if you suggest the 6 puck, whats a good and cheap one out there?
Any suggestions / Comments Etc...
Thanks!
Thanks!
Moderator in Chief
Re: Should I Save Up For A Twin Disc Or Not? (integlspwr2k)
I personally would go with a highER end "street" clutch before I went with a $1500 tilton. And I think the LSD would benefit you more. I dont think your making enough power to justify something like a tilton.
Re: Should I Save Up For A Twin Disc Or Not? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">I personally would go with a highER end "street" clutch before I went with a $1500 tilton. And I think the LSD would benefit you more. I dont think your making enough power to justify something like a tilton.</TD></TR></TABLE>
i think soo too.. its basically
twin disc and lsd
or
6puck, lsd, and ats final drive.
twin disc and lsd
or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k »</TD></TR><TR><TD CLASS="quote">
twin disc and lsd
or
6puck, lsd, and ats final drive.</TD></TR></TABLE>
with that power, i'd say 6 puck + goodies
twin disc and lsd
or
Smarter than you
For 350whp you shouldn't have to worry about a twin disk. Depending how often you race the 6 puck should last a long time at that power.
But when you go 4" downpipe it will be time for the twin disk for sure.
Re: Should I Save Up For A Twin Disc Or Not? (SHystrdyGSRtdy)
The tilton is way overkill for your goals. A sprung 6 puck will be more than enough with the lsd. I used to like the b16a final drive, but that's just me.
Drew Peacock
02-21-2004 10:41 AM
