Should I raise my CR?
I have a b18b and when i do my in car rebuild im considering bumping up the CR with a thinner headgasket. I can bump it up to around 9.4 or around 9.6(about as high as i want to go), but would this be a bad idea? the highest octane gas we have here is 91 and my tial has the .45 bar spring. im considering putting together a water injection kit which will help greatly, but without that what do you guys think? is it worth it?
Re: Should I raise my CR? (ekb18c)
I would bump up the compression. You would still be fine at 10:1 compression on 91 octane for moderate boost.
moderate boost meaning 7-10 psi?
[Modified by blufke, 10:15 PM 11/13/2002]
Re: Should I raise my CR? (blufke)
Well then why not use a stock or comestic head gasket then? I dont understand why you need to use a thinner head gasket. If you use flat top pistons, there is no reason why stock head gasket isnt good. Since you are goign to rebuild then go with 10:1 compression pistons(flat tops) adn then use stock head gasket or comestic. You will be safe for the street as long as you have proper fuel management. If your using a stock ecu then the ecu will limit the amt of boost you can run safely(proper fuel delivery). So therefore if you are using a stock ecu then i would only go as much as 7-8psi on pump gas. If you are using a fuel management system then you can run up to 14psi on pump gas. Compression is your friend esp. when it comes to spooling bigger turbos.
