Setting Fuel Pressure - Tip In, JRSC, AEM FPR, JRSC FMU, JRSC Map Controller
Hi guys! Just wanted to double check with you if I've got this right. I just installed a JRSC and plan to eventually get a Hondata. For now, I've got what is listed abouve. At idle, I set my fuel pressure @ 44 psi (Factory recommended 39-46psi) using my AEM FPR. Then, I disconnected the vaccum line going to the JRSC FMU and set the fuel pressure @ 48 psi using the JRSC FMU (JRSC Map Controller instructions suggest 45-50psi).
Is this the correct way of doing this?
Thanks!
Modified by jbs at 2:31 AM 7/6/2006
Thanks!
