screen on turbo got sucked in??
Old 07-01-2005, 12:37 AM
budget's Avatar
Default screen on turbo got sucked in??
for the last 3 months ive been running a screen over my compressor and today when i went to go re-install my downpipe i noticed that its gone... could if have gotten sucked in?? what are signs or ways i can tell if it was sucked in
Old 07-01-2005, 03:56 AM
c1civic's Avatar
i would assume that it fell off, id think it would do some damage if it got sucked in...
Old 07-01-2005, 04:06 AM
19sec beast's Avatar
Default Re: (c1civic)
You wouldn't be worrying about a missing screen if it got sucked in, lol.
Throw another on.
Old 07-01-2005, 04:08 AM
budget's Avatar
Default Re: (19sec beast)
i know it would cause damage to the turbo, but what would exactly happen and what would the car act like
Old 07-01-2005, 04:17 AM
StolenTeg's Avatar
Default Re: (suxway)
Your compressor wheel would be all **** up, if it had sucked it in, trust me you know feel it.
Old 07-01-2005, 04:18 AM
I live under a rock
spoolinlude's Avatar
it'd sound and run like ****, because you not only sucked a large piece of metal through a turbo, but most likely sent some of it into your motor.... You'd know it immediatly if it happend..... come on now, a lil common sense wouldn't kill ya
Old 07-01-2005, 04:23 AM
fanta!'s Avatar
Default Re: (spoolinlude)
**i dont see how it would just fall out w/o being sucked in
Old 07-01-2005, 04:30 AM
Default Re: (father)
Does your car get into boost? If it does, you're fine.
You'll always start to "feel" things especially when you're unsure of something.
Unless you notice a DRAMATIC difference, it's probably just your imagination.
Old 07-01-2005, 04:31 AM
budget's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19sec beast &raquo;</TD></TR><TR><TD CLASS="quote">Does your car get into boost? If it does, you're fine.
Unless you notice a DRAMATIC difference, it's probably just your imagination. </TD></TR></TABLE>
cool, got today off. test drive it in a sec
Old 07-01-2005, 05:16 AM
I live under a rock
unless you're running a massive turbo, you're not really creating enough air flow to suck a screen in even a little bit, plus if it was loose... when your weren't in boost it would have likely vibrated and fallen off....and if you did manage to somehow do it, the gap between the blades/comp housing is damn near .01, you'd likely cause the comp wheel to shatter....... if your car is running bad, its not due to sucking a screen in.... i'll put money on it, you may have however sucked something smaller in there ex) a bug, some leaves.... in which case, your car would likely run differently
moral: Try to run an airfilter by all means for street driving
Old 07-01-2005, 05:46 AM
beepy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">unless you're running a massive turbo, you're not really creating enough air flow to suck a screen in even a little bit</TD></TR></TABLE>
Something like that, but a tiny turbo on a bigger engine would create higher velocity air flow at the impeller.
Old 07-01-2005, 06:03 AM
i my honda
Global Mod
White Smoke's Avatar
Default Re: screen on turbo got sucked in?? (suxway)
It fell off
Old 07-01-2005, 10:06 AM
budget's Avatar
Default Re: screen on turbo got sucked in?? (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">It fell off </TD></TR></TABLE>
I HOPE!!!!!
car doesnt seem dramaticly diff/slower
***what other symptoms would the car give if it really did suck it though?
BTW- its a t4 turbo so im getting worried
Old 07-01-2005, 10:12 AM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suxway &raquo;</TD></TR><TR><TD CLASS="quote">
I HOPE!!!!!
BTW- its a t4 turbo so im getting worried </TD></TR></TABLE>
The symptoms of it going through would be your turbo blades looking like somebody took sandpaper to them, and your motor probably dying from injesting a whole fuckpot of metal fragments. You didn't suck it in, or you wouldn't be driving your car.
Old 07-01-2005, 10:20 AM
turbo_civic_si's Avatar
think of this, something spinning around in a perfect circle at about 80krpms. now think of what happens if something hits it? chances are you would cause a vibration in the shaft causing the bushings to touch the shaft, causeing the shaft to heat up and possibly bend or break the exhaust/compressor wheel and you would definately hear a howl and no boost. i've had something go through the turbine wheel and **** up one turbo and damage another one just enough to where i rebuilt it and it still pumps like a champ. considering that, you probably did not suck it in.
Old 07-01-2005, 10:23 AM
budget's Avatar
Default Re: screen on turbo got sucked in?? (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">
The symptoms of it going through would be your turbo blades looking like somebody took sandpaper to them, and your motor probably dying from injesting a whole fuckpot of metal fragments. You didn't suck it in, or you wouldn't be driving your car.</TD></TR></TABLE>
how the turbo compressor side sits i cant take a good like at it
Old 07-01-2005, 11:57 AM
mike1114's Avatar
not saying it couldn't happen but the screen doesn't have much surface area for the turbo to create a lot of suction on. So most likely it vibrated off one day.
How did you have it secured on there? Worm clamp? Was it gone too?
Old 07-01-2005, 12:53 PM
budget's Avatar
Default Re: screen on turbo got sucked in?? (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">not saying it couldn't happen but the screen doesn't have much surface area for the turbo to create a lot of suction on. So most likely it vibrated off one day.
How did you have it secured on there? Worm clamp? Was it gone too?</TD></TR></TABLE>
yeah i had a standard clamp on it thats not there anymore as well
Old 07-01-2005, 12:58 PM
Who is Mr Robot?
wantboost's Avatar
it vibrated off.
Old 07-01-2005, 04:32 PM
budget's Avatar
Default Re: screen on turbo got sucked in?? (wantboost)
i hope
turbo doesnt spool as loud anymore, serious problem or imagination
Old 07-01-2005, 08:08 PM
Who is Mr Robot?
wantboost's Avatar
your imagination... everything is fine.
Old 07-01-2005, 09:55 PM
MiraiZ's Avatar
I would get a proper filter! Peace of mind!!
Use the screen only when road racing at track.
Old 07-01-2005, 10:07 PM
Drew Peacock's Avatar
Default Re: screen on turbo got sucked in?? (MiraiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">I would get a proper filter! Peace of mind!!
Use the screen only when road racing at track.</TD></TR></TABLE> Haven't seen you post in along time you still have the teg?
Old 07-01-2005, 10:15 PM
MiraiZ's Avatar
Default Re: screen on turbo got sucked in?? (turbozxi)
Of course I had a chance to trade it in for an NSX, but I couldn't part from my baby...its too precious to me...
Old 07-01-2005, 10:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">Of course I had a chance to trade it in for an NSX, but I couldn't part from my baby...its too precious to me... </TD></TR></TABLE> Haha good to see its still going.
Quick Reply: screen on turbo got sucked in??
