Safe psi on stock internals....for b16a and b18 gsr?
hey guys,
just wanted to know, how much psi can these two engines handle ..while being SAFE that is,
b16a2
b18gsr
my decision on the swap ... depends on this question of which motor can handle more psi being SAFE..... and hence give me more power....
since i dont plan to change the interns and do bottom work!
and ya....its goin in a civic
cheers
b16a2
b18gsr
cheers
1 Post
Re: Safe psi on stock internals....for b16a and b18 gsr? (irtaash)
has nothing to do with boost, its just a reference. its how much torque/hp can the stock internals handle. thats the question to ask. many people have tuned b series motors (exept b20) to 350+ wheel all stock internals. its all in the tune. 300whp is a good hp number to stop at on all oem internals, for mostly daily driver car.
Re: Safe psi on stock internals....for b16a and b18 gsr? (mx621)
ahaan thanks for clarifying that
yeah am faiarly new at this...
so around 300hp shud be safe? with gud tunning
but suggest me the best engine b16a or gsr?..... less commprssion to more displacement....
1 Post
gsr will make more torque from the longer stroke, and has a better tranny for boost. 300hp is a number if tuned by a professional tuner, on a good quality turbo setup. not on some safc hack, or and other kind of ghetto tuning
i just tuned my complete stock block gsr on 10 pounds the other night, made 306hp 220tq, but all depends in the tuner, i know my tuner knows how to do his job good luck to ya
Re: Safe psi on stock internals....for b16a and b18 gsr? (SPNFEDEH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPNFEDEH »</TD></TR><TR><TD CLASS="quote">i just tuned my complete stock block gsr on 10 pounds the other night, made 306hp 220tq, but all depends in the tuner, i know my tuner knows how to do his job good luck to ya</TD></TR></TABLE>
What did you tune it with?
What is considered a good tuning system for a stock internals turbo setup at around 300whp? Full-on Hondata, or can you get by with something less like Chrome?
Re: Safe psi on stock internals....for b16a and b18 gsr? (Flatland2D)
this tells me i shud prefer gsr over b16a..... those are some decent numbers... ya hopefully i will get it tuned from a gud pro....
gdluck to u to man!
cheers
gdluck to u to man!
cheers
well the GSR willl be better for boost, I'm an N/A fan so I'd probably do the B16, but since u want boost, I say go with the GSR, max u can run on that? I'm not sure, safely I can probably say 8lbs on stock internals, I wouldn't judge it by horsepower, u can throw down 300hp at the wheels and throw a rod the next day, on stock internals, might wanna keep the PSI relatively low for a daily driver
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flatland2D »</TD></TR><TR><TD CLASS="quote">
What is considered a good tuning system for a stock internals turbo setup at around 300whp? Full-on Hondata, or can you get by with something less like Chrome?</TD></TR></TABLE>
i use hondata, youll gain more tq with a gsr, i saw a stock b16 dyno 10 pounds, made 270hp and 176tq
bdw am talking about the jdm spec b16 and b18 gsr...since i would be swapping the jdm ones
with 10:4:1 & 10:6:1(gsr) compression ratios....
just get the GSR motor.
with the right turbo set up, you can make 300 or a little over 300whp on 10psi with a good tune.
oh yeah, the GSR isn't the "BEST" tranny for boost for whoever made that comment about the GSR has the best tranny for boost.
Re: (hondaeg8)
bdw i am always mentioning the jdm spec ones....since i guess jdm's are the ones i am gonna be getting in my part of the world......
upon comparison i figured that.... Although all USDM spec engines have slightly less hp..... but also have less compression !
jdm b16a 10:4:1
jdm GSR 10:6:1
So are the usdm ones better for boost on stock interns? by having less compression.... or the difference is not all that big......and the jdm gsr is still the right choice?
cheers
jdm b16a 10:4:1
jdm GSR 10:6:1
cheers
Re: (irtaash)
dude, people have already gave you their opinions. they know you said JDM motors and we know the compression numbers. you have also mentioned about it a couple of times already.
the GSR motor is a BETTER motor to boost on stock internals. it comes with more power and you'll make more tq than you would with the b16 motor. its a 1.8l motor and is a good motor to run.
if you CAN afford the GSR motor , then get it............ ENOUGH SAID!!
if you can't afford one, then get the b16 motor
its not that hard to decide.
Re: (hondaeg8)
yeah i figured i was kinda repeating things alot..... :S
prolly cauz of my first ever build.... so excuse me for that
yeah gsr is it then... thanks to all...
wud post up when am done with it....
cheers
cheers
