RX-7 injectors instead of 450's and VAFC
Guest
Posts: n/a
Has anyone tried this being that the rx7 injectors are saturated, instead of doing the 450's resistor box and vafc route? The turbo'd ones are a little big but the NA ones on the 2nd gens are like 460 I believe? Someone please correct me if I'm wrong?
Re: RX-7 injectors instead of 450's and VAFC (egizzle6)
you would still need the v/safc
also it is probably not worth the cost. im sure they are much more expensive, and harder to find than the DSM injectors. and a resistor box is $2.50
Guest
Posts: n/a
Re: RX-7 injectors instead of 450's and VAFC (envision2teg)
There actual pretty cheap and I wouldn't need the FI 550cc anyway. Hell the injector clips can be bought at autozone and NA 2nd gens are a dime a dozen at my local pick and pull. The DSM guys use them for cheap upgrades over the 450's. Yeah I'd have to get a vafc to tune the injectors or they'd flood my engine with something to adjust them. Just an idea?
Guest
Posts: n/a
There's two 460's at like 4 bucks on ebay bust you'll need to find two more. They just need to be from 88 for a round saturated injector setup or the other years for a peak hold injector. Some have a oval shaped injector also.
Guest
Posts: n/a
Injector Information
Mazda RX-7(Gen 1 and 2) Fuel injector identification guide
Note that some injectors carry the same part number as others but plug styles and
resistances can vary. Low impedance refers to 2-3 ohms, high impedance refers to
12-13 ohms.
Year type impedance plug style plug notch position flow rating color part number
84-85 13B NT low square center 680cc orange 195500-0900
86-87 13B NT low square center 460cc red 195500-1350
86-87 13B T low square center 550cc tan 195500-1370
88 13B NT high square offset 460cc purple 195500-1350
88 13b T high square offset 550cc purple 195500-1370
89-91 13B NT high oval center 460cc red 195500-2010
89-91 13B T high oval center 550cc purple 195500-2020
As a side note, replacement fuel injector clips(for wiring harness) can be
obtained from auto parts stores to replace broken stock clips. I got the parts
from autozone:
GP Sorenson part 800-9416 Fuel Injector Connector
More about injector impedances on 2nd generations:
86 and 87 model cars used low impedance(2-3 ohm) injectors. Low impedance
injectors have a center notch on the plug. The wiring harness used with LI
injectors integrates an injector resistor pack, wired inline between the ECU and
injectors(under stock air box) to bump overall load seen at the ECU to 12-13
ohms.
88 and after models used high impedance injectors. 88 HI injectors have an offset
notch on the plug, and all post 88 injectors are HI with an oval plug(until 3rd
generation side feed injectors which are totally different). The wiring harness
on these models deleted the injector resistor pacl, carrying the 12-13 ohm load
from the injectors directly to the computer.
12-13 ohms.
from autozone:
ohms.
Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO »</TD></TR><TR><TD CLASS="quote">Im using these on my EJ1
86-87 13B NT low square center 460cc red 195500-1350</TD></TR></TABLE>
how was the fitment into the rail?
Tony Starks
12-01-2003 11:45 AM
superduperman
01-29-2003 09:39 PM
lsvtec101
12-20-2002 07:36 AM
