Running a P28 and hondata 2b with no turbocharger
Okay here is my question-
I have a P28 that has been tuned (for a turbo Integ) and a hondata 2b. My supercharger is in Sacromento, two hours away...
Can I install the ECU and hondata now? Will my engine run like crap?
Will i be able to install the hondata even AFTER i get the supercharger on, or will I have to run check valves all the way home till I take the hondata to a tuner?
I mostly am trying to cut down on the install time for the weekend.
BTW - I have a D16Y8
These may seem like dumb questions to some of you super FI guys, but im (slowly) learning
Re: Running a P28 and hondata 2b with no turbocharger (FMXer)
You can put it in just as long as you have the same injectors and fuel pressure the other guy did you should be fine. Once you get the SC on, you will need to get it retuned simply because the SC runs really hot and you are gonna have to adjust the timing less than what a turbo would be. You wont need check valves with the SC.
art
art
On a JRSC? Not unless you relocated the map sensor already.....
if it's tuned for larger injectors and you are running small ones, the car will lean out and might not be drivable.
"You wont need check valves with the SC"
My MAP senser wont throw a cel??
Re: Running a P28 and hondata 2b with no turbocharger (inspyral)
well! I've just been throwen all backwards
what would one need the Jackson Racing MAP limiter for then??
