runing a ctr pistons in my b16a and need info on how to build this
ok heres the deal i have a b16a and i just bought some ctr pistons.what i need to know will a stock head gasket work on this or will i need anthor one.also i have eagle rods ,arp head studs and rod bolts.what crank bearings will i need, i plan on reving to 9000 on this setup.also any info would be great.
1 Post
Re: runing a ctr pistons in my b16a and need info on how to build this (kidrolla)
well if ur asking for crank mains bearing then oem is ur friend .. or at last a set of acl's ... check ur mains code stamped on ur block and then the numbers on ur cranks on and see what color u need
mario_pic
19
01-10-2009 02:55 PM
SomeDude56
10
01-17-2006 05:19 AM
