RPM Gauge is jumping...
Hi, I have a '94 Integra GSR, JRSC 10.8psi with a S200.
I trie diferent maps to have one that I can use as a base for tunning, but I have a problem in the RPM reading in all:
- At 5,000 rpm I have a little jump at little trothle, it is solve pushing the trothle a little more.
- At 6,000 rpm my rpm gauge start to be crazy, it start to jump 500 rpm up or down, and at 7,000 rpm it start making jumps that can go to 3,000 rpm and return to the reading. In this situation, the car can't pass 7,400 rpm (I have the rpm limit set in 9,200 and boost cut at 12.5psi)
I need help and ideas to make a troubleshuting.
Thanks in advance,
Dariusz
Thanks in advance,
Dariusz
Re: RPM Gauge is jumping... (dariusz)
first off check your ground wires on tranny side of engine!!!
and hopefully some others post cause i dont know what else it could be...
chris
chris
Re: RPM Gauge is jumping... (FFgeoff)
I think the same, adn the other possible is that the rotor make a interferetion with the MSD cables (the two one that go out the distributor cap).
Thanks all for the help
HBRIDER
07-04-2008 03:03 PM
honda genome
03-31-2007 10:25 AM
