Ross Pistons, Pins and Rings
Can someone give me feedback on these...
http://cgi.ebay.com/ebaymotors/ws/eB...873086648&rd=1
I've been told the pins are a weak link. Also, I was thinking of the -6.1 cc which is roughly 9.4:1 on a B16 VTEC head. Is this a good compression for turbo?
Re: Ross Pistons, Pins and Rings (7rrivera7)
The ross pistons that we used had a .866" wristpin instead of the typical .827" pin. This makes for a stronger pin but a weaker piston. In reality though, you won't see any of those problems unless you are making over 700hp.
Re: Ross Pistons, Pins and Rings (tony1)
Re: Ross Pistons, Pins and Rings (Arturbo)
Yeah, i'm famous The next one will be about our engine and what we do to make it hold together. Don't expect to get any secrets though, we're not stupid!
Ross has beena round since the muscle car era...great pistons. People use to use them in super High Compression V8's big *** dome pistons.
Re: Ross Pistons, Pins and Rings (BorderM3)
Good input guys but how about the compression. Is 9.4:1 (the Ross) a good happy medium between running aspirated until the turbo spools up and also during boost? Is 10.5:1 (the current JE) too high for boost?
im gonna be using the 10.5:1 pistons in my FI setup...i dont plan on running insane amounts of boost though, and the comp. should be slightly lower when all is said and done...but with the right tuning and setup, i hope to hit 15-18 psi or so at the track..
the way i figure is that the higher comp. pistons will make the same power on lower boost, so i wont have to risk as much when i boost lower and its tuned well...just my .02
unknown0001
03-25-2006 10:39 AM
