Road Race Engineering catchcan works for me
Well after trying to find a can that would fit in my cluttered engine bay, I ended up going with the small RRE catchcan. It too was kinda hard finding an ideal place for it too mount...when I looked at my fuel filter brackett and ding ding ding. PERFECT. Just thought I'd share for those in a similar bind.
Re: Road Race Engineering catchcan works for me (portenio78)
Looks good. I need a small catch can for my valve cover breather. I think this is made by Jaz. At least it looks the same. How did you mount it there, btw?
Looks nice.
It has a drain on the bottom right?
I might replace my homemade catch can with one of those so I can drain the oil out more easily.
Re: Road Race Engineering catchcan works for me (EJ1 wilcox)
Has anyone running this can noticed if it fills up quickly compared to one with larger diameter lines coming to it?
I'm not saying this is happening to others I'm just asking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by portenio78 »</TD></TR><TR><TD CLASS="quote">It comes with a brackett...but I just drilled a hole in the fuel filters brackett and used the supplyed bolt to attach.</TD></TR></TABLE>
Did you have to remove the bracket? I hated changing my fuel filter, and the filter and bracket come out together. Did you remove the entire assembly before drilling the hole, or can it be done by just removing the battery for some more room?
Re: Road Race Engineering catchcan works for me (B16A Grenade)
im currently on my second setup running the rre catchcan. i also mounted mine between the battery and the fuel filter.
they are 49 bucks from http://www.roadraceengineering.com
