RISKS AND GAINS FROM TURBOING YOUR CAR
i have a turbo B18 in an eg, i love the power gains from it. but im concerned about the mechanical reliability of it. also, does it cause excessive engine wear? second Q, i have a straight 3" pipe w. no catalytic conv. and fumes are getting in the cabin. is that normal?? is it the turbo? or the fact that the cat is missing??
Re: RISKS AND GAINS FROM TURBOING YOUR CAR
sounds like you're missing a gasket somewhere in your exhaust system, probably where the cat used to be if you have a test pipe in there.
well, thats what i thought at first but i looked and theres none. its a straight exhaust pipe with no cat, or muffler. just one long tube. it could be poor welding. i bought the car with that exhaust.
Is your dumptube from the waste gate recirculated into you downpipe? If not, that could also be the source besides a leaking exhaust.
If you aren't constantly in boost, there really shouldn't be any more stress on the engine. From what I've been able to gain, as long as you are boosting conservatively and have a good tune, you shouldn't have to worry too much.
I second the exhaust leak. |
im running a conservative 5 lbs.
ha 5psi is hardly testing that motor.
pull the exhuast off and check all the welds possibly re weld or replace exhuast |
B18B or B18C
These engines can handle decent power in stock form. Many push around 300whp daily with no issues. Obviously, the GSR engine is stronger, but at 5psi I don't think you have anything to worry about IF you have a solid tune. |
its the b18b, i wanted it as a daily driver. so with 5psi. and a gsr trans i think ill be able to get away most power without blowing the motor. but yea ima check the welds. a friend told me also to check my shifter. it may be coming in through there too.
There's supposed to be like 2 rubber seals around your shifter. They aren't expensive, like $15 together from Honda.
you run the risk of having too much fun with a turbo and the chance in getting your car towed and you goin to jail for speeding.
Have a friend hold a rag in the end of the muffler, with the car running. Then look under the car to see if you notice any exhaust gas coming out anywhere it shouldn't be. You should be able to hear the leak as well, if there is one.
As for the turbo/reliability thing, get your car tuned. |
you will get a better response at the Forced Induction forum.
Originally Posted by rick_rabies
(Post 39137884)
and are you serious, OP... is the cabin supposed to fill up with exhaust fumes?! |
smoking :(
Risk = Wallet
Gain = horsepower |
Originally Posted by Tony the Tiger
(Post 39141800)
Risk = Wallet
Gain = horsepower |
(Post 39141800)
Risk = Wallet
Gain = horsepower |
(Post 39137884)
I can get from 100km/h to 200 km/h in about 6-7 secs, so before I pass the next intersection, I am already back at the speed limit...lol It is only those 300WHP heros that need a long stretch of road to pull any good speed to impress their friends...ROFL I go there, get the job done, slow down in a span of under 8 secs. |
Originally Posted by coquieg6
(Post 39136693)
ls tranny gears are longer so u have a higher boost period |
Originally Posted by 95teg-okc
(Post 39145487)
Really. - Derek |
(Post 39145487)
I believe the more power you have the worse wear and tear becomes. Same with heat issues which usually scale with increased power in just about any machine.
(Post 39145487)
http://img.photobucket.com/albums/v2...Avatars/NO.gif |
lol yea, thanks guys
