Rhd integra xsi <--going boost good or bad
well i just picked up a integra xsi and i would like to boost it but im looking around and the kit i like the most is the drag kit .. 10.4 is stock comp so how much boost is that good for ..not sure on what ecu to use either .. .any sugg
Re: Rhd integra xsi <--going boost good or bad (MrJdmJimi)
If you have an xsi then you may have the pr3 ecu which is obd0. I plan on running BRE when i get my setup finished this summer.
I had a RSi with an obd1 b16 and a rev-hard kit. I switch the car over to obd1 and used chrome. If you go with the drag kit, it will creep a little. Ditch the FMU and get some 550cc injectors, an in tank 255, and Hondata/Chrome. Get it tuned and run 10psi or less and you will be fine.
Re: Rhd integra xsi <--going boost good or bad (FUCATYPR)
Yeah thats the route I am going. I decided to convert over so I can take my car to my local tuner. All I need is a distributor and harness and im good to go. My tuner uses crome as well.
