Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   revving out of gear (https://honda-tech.com/forums/forced-induction-16/revving-out-gear-591864/)
djnikko Aug 14, 2003 01:53 AM
revving out of gear
when revving out of gear should u see boost on your boost gauge? or is it only in gear u build up boost? I cant see why it would be any dfferent i would of thought u see boost whatever... can anyone set me straight on this? do u see more boost when in gear? higher gears lower gears? thanks guys https://honda-tech.com/forums/images...es/emsmile.gif
psileepR Aug 14, 2003 02:14 AM
Re: revving out of gear (djnikko)
unless its a tiny tiny turbo you wont see boost in neutral.
Boost is built with load on the engine. going up hill for example.
djnikko Aug 14, 2003 03:55 AM
Re: revving out of gear (psileepR)
i see, thanks mate. does the boost increase wuite steadily? the reason i ask is that i have no idea what psi the turbo is set up so i wanna be able to back off if i see it rising anywhere over 10psi ... i spose when u take your foot off the pedal the boost will increase spose its common sense just checking as ive never had experience with this before.
