rev hard turbo results any good?
im buying the rev hard 2 kit for my integra gsr. what HP are you guys running with this kit @ what psi? im running stock bottom end so 7psi will be the limit. pics would be great!!
...also, do i have to customize the flange for the downpipe??
Re: rev hard turbo results any good? (JunIntegra)
Re: rev hard turbo results any good? (Maxime)
ive done searches and noone really focuses on the power of these kits. if you have a good link, please post. other than that, any good HP numbers or track times?
Re: rev hard turbo results any good? (NOSED_CRX_VTEC)
welll...
on my rev hard stage 2 kit from about 2.5years ago...running 10psi
92 si hatch(nothing taken out)
bfg drag radials
ls engine swap
thermal 3 inch exh. no cat
act xtreme 6 puck
the car ran a 12.4 @112 with a 1.960ft.(on the drag radials)
about the downpipe....if its like mine the down pipe will come down to the oil pan..than u will need to buy a section of pipe and "finish" the down pipe. than put a flange on it and connect it to the exhaust.
bfg drag radials
ls engine swap
act xtreme 6 puck
XaznPKdogX
01-27-2002 01:32 AM
