Resistor Pack off of a 1st Gen Talon
*I NEED SOME HELP*
I bought a used resistor pack off of a 1st gen talon for my 450cc injectors for my turbo kit... but the resistor pack has got 5 wires, 4 black and 1 white... Which wire goes were?
Re: Resistor Pack off of a 1st Gen Talon (Fonzie544)
The white goes to a fused 12VDC that switches with the ignition. Take one black wire to one side of each fuel injector. Take the other side of each fuel injector to the approprite pin on the ecu output.
That is assuming that your honda ecu sinks instead of sources.
Re: Resistor Pack off of a 1st Gen Talon (danl)
Hello Again,
Sorry im really not a good electrical kinda guy... with the injectors they have two wires... different colors... now each one of the black wires off of the resistor box goes to each injector... (which color on the injector wire?) next you said i have to run the wire back to my ecu... where exactally does that go into like spot wise? And finally do i just use any kinda wire that is 12 volt compatiable?
PLEASE GIVE ME A RESPONSE AS SOON AS POSSIBLE!!!
i thank you also for helping me with this situation!
Mike~
Mike~
Orangevirus1
07-09-2013 07:55 AM
