resister box wiring diagram???HELP
memoryFAB.com representative
i know it was here about 6 months ago and i did a search and i found nothing. if anyone could help me i'd greatly appreciate it. thanxx
Re: resister box wiring diagram???HELP (2muchPSI)
the easiest way of doing it is basically finding that plug in the harness that has like 15 something wires but has a plug on the other end. this plug has about 6 yellow with black striped power wires and 4 of them are the power wires for the injectors. you can check this using a volt meter and check for continuity.
pull those 4 wires out of the plug and the resistor box will have 4 black wires and 1 red, which means those 4 black wires go to the 4 injector power wires and the red wire is for power for the resistor box, that can go to any other yellow and black wire other than injector ones.
that should pretty much be it.
There are a bunch of threads on here with it.
Search under "Ladysman" because he did a great writeup,
And search under my name "T-RO" because just last month I did a solderless install write up...
