Removing Turbo need help removing oil lines
It was a real pain removing the oil pan the first time around, so I'd rather avoid it. Is there any way I can just plug the bung for the return lines?
Re: Removing Turbo need help removing oil lines (BoostnSD)
yep buy a -10 AN cap and screw it on there. that's of course if you have a -10 AN threaded return on there.
if it's just some crappy hose fitting put a hose on it and a bolt in the other end of the hose and clamp the hell out of it.
Re: Removing Turbo need help removing oil lines (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB »</TD></TR><TR><TD CLASS="quote">yep buy a -10 AN cap and screw it on there. that's of course if you have a -10 AN threaded return on there.
if it's just some crappy hose fitting put a hose on it and a bolt in the other end of the hose and clamp the hell out of it.</TD></TR></TABLE>
bingo
bingo
gunmetalcivic
12
04-01-2006 02:48 PM
KC GSR
12-02-2003 02:09 PM
