The Reliability Thread. Everyone please check in.
There have been a bunch of questions like "how much can a stock b16 handle" "reliability issuee" etc. etc. Mainly it depends on the engine. the problem is that not everyone has the same engine, mods etc. so heres the thread of reliability.
If you are turboed please post Engine code-(b16, b18 etc.) Sleeves-(Stock, GE, Benson) Compression Ratio(10.2:1, 9:1, etc) Pistons-(Stock, Wiseco, etc.) Rods-(stock, Eagle, etc.) Turbo-(t3/t4, t28, gt30r, etc.) Boost pressure-(14psi, 1bar, etc.) Turbo Manifold-(ramhorn, log, etc.) Wastegate-(HKS, Blitz, Tial, etc.) Blow off Valve-(HKS, Tial etc. Intercooler type and size(Bar and plate 23x10x3, etc) Current Miles on Car-(144,000, etc.) Problems on car before turbo-(hiccups, no VTEC engagement, etc.) Miles on Car when turboed-(24,000, etc.) Problems on car after turbo(current problems, or fixed problems) Installed-(Professionaly or by yourself) Tuned-(With what by who) Horsepower/Torque-(300/200) If you dont feel like filling out this form just put in basic specs, miles running and problems Thanks P.S if anything should be added please contact me via PM Modified by Dr.D at 4:25 AM 6/28/2006 Modified by Dr.D at 6:26 AM 6/28/2006 |
Re: The Reliability Thread. Everyone please check in. (Dr.D)
I feel what sleeves you're running is worth mentioning, so I threw that in there too.
Engine code-B18C1 Compression Ratio9.43:1 Sleeves-Stock Pistons-Wiseco 81.5mm Rods-Eagle Turbo-Garrett GT3076R .63 A/R Boost pressure-12psi normally, scramble boost is 17psi Turbo Manifold-Full-Race AC Ramhorn Wastegate-Tial 44mm Blow off Valve-HKS SSQV Intercooler type and size-PTE 600HP Current Miles on Car-91K Problems on car before turbo-Not enough power Miles on Car when turboed-50K with drag kit, 77K on new setup w/built motor Problems on car after turbo-Had some overheating issues, replaced Tstat and got a fluidyne rad and it runs great now Installed-Built motor, installed turbo kit, tuned myself https://honda-tech.com/forums/images/smilies/emthup.gif I seem to be one of the few on here who don't have a ton of problems with their setup. Runs great, has a nice powerband, and is a reliable daily driver. |
Engine code-d16y7
Compression Ratio-9.4:1 Pistons-Stock Rods-Stock Turbo-13t from '02 WRX Boost pressure-10-12psi Turbo Manifold-std/hf w/ adapter plate Wastegate-Internal Blow off Valve-1g DSM Intercooler type and size-JRC 8" Current Miles on Car-117k+ Problems on car before turbo-None Miles on Car when turboed-62.5k Problems on car after turbo-none Installed-Self Tuned-Self Years boosted-3+ |
Re: (scttydb411)
Engine codeB18C1
Compression Ratio Stock Sleeves-Stock Pistons-Stock Rods-Stock Turbo-GT3076R .82 a/r Boost pressure-9/18 Turbo Manifold-Full-Race Non-AC Ramhorn Wastegate-Tial 44mm Blow off Valve-Tial 50 mm Intercooler type and size- PWR 20x8x3 Current Miles on Car-63,000 Problems on car before turbo-Horribly slow Miles on Car when turboed-36,000 Tuned By- Jeff Evans Installed By- Epic Tuning Problems on car after turbo-None whatsoever, second kit-third turbo, runs great, want to go faster https://honda-tech.com/forums/images/smilies/emwink.gif BTW, great thread https://honda-tech.com/forums/images/smilies/emthup.gif Modified by a1320addict at 1:58 AM 3/7/2007 |
Re: The Reliability Thread. Everyone please check in. (boosted92)
Engine code-B18C
Compression Ratio11.3.1 Sleeves-Stock Pistons-jdm itr Rods-gsr Turbo-precision sc-61 Boost pressure-6psi Turbo Manifold-spoolin performace Wastegate-Tial 38mm Blow off Valve-greddy rs Intercooler type and size-PTE 350HP Current Miles on Car-150K Problems on car before turbo-Not enough power Miles on Car when turboed-7677 km before turboed, now 18,3xxkm Problems on car after turbo-Had some overheating issues, replaced it with spoon Tstat and fan switch got a fluidyne rad along with Installed-intsalling turbo kit myself along with some friends https://honda-tech.com/forums/images/smilies/emthup.gif Runs great, has a nice powerband, and is a reliable daily driver. Made 281whp and 184tq. |
Re: The Reliability Thread. Everyone please check in. (1Quikgsr)
Engine code-B16A2
Compression Ratio9:1 Sleeves-Stock Pistons-Endyn 81mm Rods-Eagle Turbo-Precision SC34 (57 trim/.63 a/r) Boost pressure-14.5psi Turbo Manifold-InlinePRO Cast SS Wastegate-Tial 38mm Blow off Valve-Greddy Type S Intercooler type and size-Spearco Bar & Plate Current Miles on Car-83K Problems on car before turbo-None Miles on Car when turboed-33k Problems on car after turbo-Broke clutch disc and thats about it Built motor, Installed motor/turbo and tuned myself |
Engine code - B20Z re-sleeved with Darton MID sleeves.
Compression Ratio - 9.2:1 Pistons- JE 84.5mm Rods- Eagle Turbo- garret t3/t04e 57-trim .63 a/r Boost pressure- 10psi daily - 15-17psi occasionally Turbo Manifold- spark racing tubular a/c manifold. Wastegate - tial 38mm. Blow off Valve - HKS Intercooler type and size- JRC 8" tube/fin design Current Miles on Car - 175,000 km Problems on car before turbo- cracked #1 cylinder sleeve when was N/A. Miles on Car when turboed- 155,000km Problems on car after turbo - poor tuning by me led to dentonation and damaged original wiseco pistons. https://honda-tech.com/forums/images/smilies/emsad.gif https://honda-tech.com/forums/images...s/emthdown.gif , couple minor oil leaks which were easily fixed. Installed - every nut, bolt and weld installed by me. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: The Reliability Thread. Everyone please check in. (non-VTEC)
Engine code - B18c1
Compression Ratio - 10.1:1 Pistons- Wisesco 81mm Rods- Probe IB spec Turbo- gt3571r Boost pressure- 16psi all day long Turbo Manifold- SpoolinPerformance Street Power Wastegate - tial 44mm Blow off Valve - Tial Intercooler type and size- JRC 8" tube/fin design Current Miles on Car - 48kmls Problems on car before turbo- nothing Miles on Car when turboed- 10kmls+ still going strong Problems on car after turbo - second car with turbo setup since last project was stolen had a good idea what i needed...Koyo Radiator, FAL fan for civic half core radiator, Fan Switch jumped recently new problem arrise after fully warm up engine would shut off coming to a complete stop...rpms down...a few fellow hondatechers said the rolling idle injector duty cycle needs to be raised Installed - by Phil (Spoolinperformance) and I |
Engine code 84mm b16 stock crank
Compression Ratio 9:1 Pistons JE Rods Crower Billets Turbo for 3 years drag To4B the last year F-R t3t67HO .70 / .82 Boost pressure drag kit 17 psi f-r kit 28 psi Turbo Manifoldagain drag then f-r equal length Wastegate drag kit 38mm tial f-r kit 44mm tial Blow off Valve drag kit hks ssq f-r kit 50mm tial Intercooler type and size drag small spearco f-r kit 22x11x3 backdoor Current Miles on Car 165k and it dont look like it Problems on car before turbo nothing except a rich condition, 2 years fmu but the last 3 w/ hondata Miles on Car when turboed 152k Problems on car after turbo just broken axles and a little finicky idle, 1200's Installed built, tuned, and installed by me the engine is really tired, too affraid to check compression, but it has been to 2 north east NHRA events, gets better every run till the axle broke. any time you get into a build like this, reliability comes into play. new gsr in the works, carrillo, cp ctr, next stop 725whp and 9's hopefully. id like to do 9's with the b16 but i think it is alittle too tired. it has taken everything i have thrown at it. |
Engine code-b18b1
Compression Ratio- 9.2:1 Pistons-stock Rods-stock Turbo-sc34 .60/.63 Boost pressure-14-15psi Turbo Manifold-inline pro Wastegate- Tial 38 Blow off Valve- greddy type-s Intercooler type and size- Precision 8" tall Current Miles on Car- don't know Problems on car before turbo- No Turbo Miles on Car when turboed- don't know mileage....about 3 years Problems on car after turbo-headgasket leak...getting bit and wanting more speed ($$$) Installed-DIY |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr.D »</TD></TR><TR><TD CLASS="quote">There have been a bunch of questions like "how much can a stock b16 handle" "reliability issuee" etc. etc. Mainly it depends on the engine. the problem is that not everyone has the same engine, mods etc. so heres the thread of reliability.
If you are turboed please post Engine code-b18c5 Compression Ratio10.6:1 Pistons-Stock Rods-Stock Turbo-t3-to4e-60 Boost pressure-10-11 Psig Turbo Manifold-cast iron Wastegate- Tial Blow off Valve-Greddy - S Intercooler type and size Spearco, don't remember the dimensions Current Miles on Car- 55K Problems on car before turbo- the only problem was it was slow as hell Miles on Car when turboed- 14K Problems on car after turbo - nothing until about 53 K (blew ring lands on pistons 3 and 4 Installed - myself If you dont feel like filling out this form just put in basic specs, miles running and problems Thanks P.S if anything should be added please contact me via PM</TD></TR></TABLE> |
Re: The Reliability Thread. Everyone please check in. (Mr Wonderfull)
Engine code-B18C1
Compression Ratio-8.9:1 Sleeves-Golden Eagle Pistons-Wiseco 81.5mm Rods-Crower Steel Billett Turbo-SC61 Boost pressure-15psi Turbo Manifold-Neukin Ramhorn Head Port/Polish Ferrea Oversize Ferrea Everything Tranny LS, Quaife, ACT Wastegate-Tial 44mm Ignition MSD 6A, Cap/Coil/Plug Wires Blow off Valve-GReddy Type-S Intercooler type and size-Precision 750hp Current Miles on Car-138K Problems on car before turbo-None Miles on Car when turboed-137K Problems on car after turbo-None EMS Hondata S300 Old setup, Engine code-B18C1 Compression Ratio-9.1:1 Sleeves-Golden Eagle Pistons-JE 81.00mm Rods-Crower Steel Billett Turbo-T3/T4 .57 Trim .63 AR Boost pressure-13psi Turbo Manifold-Revhard Wastegate-HKS 40mm Blow off Valve-GReddy Type-S Intercooler type and size-Trust Type 24 Miles on Car when turboed-120k - Problems on car after turbo-Blew 2 tranny's, Blew Headgasket, Fuel Injector Failed, Turbo Seal Leak How Long Lasted 13k Miles, Melted all 4 pistons on a severe overboost https://honda-tech.com/forums/images...s/emthdown.gif EMS SAFC https://honda-tech.com/forums/images...s/emsmilep.gif https://honda-tech.com/forums/images...s/emthdown.gif Modified by 96 GSR-T at 12:14 AM 6/25/2006 Modified by 96 GSR-T at 12:19 AM 6/25/2006 Modified by 96 GSR-T at 10:09 AM 6/27/2006 Modified by 96 GSR-T at 12:12 PM 6/27/2006 |
Re: The Reliability Thread. Everyone please check in. (96 GSR-T)
Engine code-b18c1
Compression Ratio-9:1 Pistons-CP Rods-Crower Turbo-sc34 Boost pressure-6psi for now Turbo Manifold-ramhorn Wastegate-Tial Blow off Valve-HKS Intercooler type and size-JRC Current Miles on Car-128k Problems on car before turbo-none Miles on Car when turboed-125k Problems on car after turbo-low idle sometimes (uberdata) Installed-myself |
Re: The Reliability Thread. Everyone please check in. (kuja)
great thread, ill update this with my setup tomorrow
Re: The Reliability Thread. Everyone please check in. (I Have an STD)
Engine code-B18A
Compression Ratio-9:1 Sleeves-Golden Eagle H-D Pistons-JE 84mm Rods-Eagle Turbo-Garrett GT3567R Full Race Spec Boost pressure-15psi Turbo Manifold-Jay Thornton Ramhorn Wastegate-Turbonetiscs Evolution 35mm Blow off Valve-SSAC "RFL" Intercooler type and size-Tube and Fin 24x18x3 Engine Management Hondata S200 Boost Current Miles on Car-59,000 Problems on car before turbo-None Miles on Car when turboed-13,000k Problems on car after turbo- Blowing the hot side pipe off the turbo, Fixed with Vibrant reinforced couplers and T-Bolt clamps, traction in the low gears, have broken 2 axles on 2nd-3rd shift, Not tuning the car has lead to the rings washing out. I will be replacing the rings 1st week of July, and having St00pid tune it July 7th Installed-Everything Done by myself I added engine management, cause in my opinion that is the deciding factor on how a turbo car is going to live. https://honda-tech.com/forums/images/smilies/emthup.gif https://honda-tech.com/forums/images/smilies/emthup.gif to the OP...great idea |
Re: The Reliability Thread. Everyone please check in. (BrokeAssWhiteboy)
Engine code-(b16a2
Compression Ratio(10.2:1 Pistons-(Stock Rods-(stock Turbo-(t3/t4 Boost pressure-9psi Turbo Manifold-drag Wastegate-tial 38mm Blow off Valve-(HKS Intercooler type and size(Bar and plate 24x10x4 Current Miles on Car- 135,000 km Problems on car before turbo- nothing perfect Miles on Car when turboed-10,000 km Problems on car after turbo, weird idle, eats spark plugs like fat kids eat cake, Installed-(Professionaly |
dam, good thread why not h-series, k or d-series
Engine code-B18C1
Compression Ratio- 9:1 Sleeves-Bensons Pistons-CP Rods-Pauter Turbo-Garrett GT35R .63a/r Boost pressure-14-16 Turbo Manifold-Equal length Wastegate-Tial 44mm Blow off Valve-Greddy type S Intercooler type and size- Precision medium management- Neptune Transmission-Quaife LSD, Competition clutch Head-GSR cams, Supertech springs/retainers, stock ports & valves Current Miles on Car- 400 roughly Problems on car before turbo- none Problems on car after turbo- still a power restriction somewhere, suspects: Stock TB, stock port head(only springs/retainers, .63a/r exhaust side on turbo too small (opinions are welcome on whats holding me back) otherwise car is a beast https://honda-tech.com/forums/images/smilies/emthup.gif |
Engine code- B18B1
Compression Ratio 9.3(?):1 Pistons-Stock Rods-stock Turbo- T3/T04e 57 trim .63 a/r Boost pressure- 8 PSI Turbo Manifold- Log Wastegate- SSAC 38mm Blow off Valve- SSAC 55mm Intercooler type and size Bar and Plate 28x8x3 Current Miles on Car-145,000 Problems on car before turbo- Nothing major Miles on Car when turboed- 140,000 Problems on car after turbo Oil leak from the turbo inlet due to wrong size fitting (easy fix), leaking oil pan gasket due to shitty install (easy fix), some overheating issues which was due to a shot radiator. Installed- Installed partially by me but mostly done professionally EMS Uberdata I think engine management is a good category to add when finding out Reliability. |
Engine code-B16A2
Compression Ratio10.1:1 Sleeves-Stock Pistons-Stock Rods-Stock Turbo-TD05H-18G (Greddy Kit) Boost pressure-5.5psi Engine Management-Uberdata Turbo Manifold-Greddy Wastegate-Internal Blow off Valve-Greddy Type S Intercooler type and size-Treadstone 28" x 6" Bar and Plate Current Miles on Car-22,800 Problems on car before turbo-None Miles on Car when turboed-21,000 Problems on car after turbo-Very occasional Uberdata glitches, nothing mechanical Installed-Installed turbo kit, tuned myself |
Re: The Reliability Thread. Everyone please check in. (Buzzbomb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Buzzbomb »</TD></TR><TR><TD CLASS="quote">Engine code-B16A2
Compression Ratio9.1.1 Sleeves-Stock Pistons-CP Rods-EAGLE Turbo-T3/T4 57 trim w/.63 exhaust housing. Boost pressure-w/g 10lbs lax boost 21lbs. Engine Management-S300 Turbo Manifold-One off, built by Turbo-Charged. Wastegate-Tial 38mm Blow off Valve-HKS SSQV Intercooler type and size-Precision 600whp. Current Miles on Car-86,xxx Problems on car before turbo-None Miles on Car when turboed-76,xxx Problems on car after turbo-VAFC @ first, roasted ringlands. Rebuilt. Installed-Installed myself, Tuned/SlowMotion Columbus, Oh. Whp/Wtq - 406.8 & 308.4 . Pushing for 500whpp or limits of the turbo soon.</TD></TR></TABLE> https://honda-tech.com/forums/images/smilies/emthup.gif |
Engine code - b18c1
Compression Ratio - stock Pistons - stock Rods - stock Turbo - garrett t3/to4e .63a/r .57trim Boost pressure - 9psi Turbo Manifold - custom short runner top mount manifold Wastegate - 38mm tial Blow off Valve - greddy type RS Intercooler type and size - SSAC bar and plate 26x6x3.5 Current Miles on Car - 70k Miles on Car when turboed - 58k Problems on car before turbo - none Problems on car after turbo - when running fmu, i got a CEL for the highflow cat. idling problem since i got tuned on crome Installed - friend Management - Crome HP/Torque - 278hp/189ft-lbs |
bump for more
everyone post what psi yor runnig and what power your producing.
BUMP FOR GR8 THREAD |
Re: (jdmbb6-t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmbb6-t »</TD></TR><TR><TD CLASS="quote">dam, good thread why not h-series, k or d-series</TD></TR></TABLE> y not? all engines if misunderstood
| All times are GMT -8. The time now is 05:08 AM. |
