Relay and wiring question - electrical guys help please. Nitrous bottle heater x2.
I have two 10 lb bottles in my car and I want to run two bottle warmers to heat them up to a yummy pressure. I was thinking about (mainly becuase of cost) going with the dynotune.org heaters, but just buying 2 heating pads and one pressure sensor, switch, relay, etc.
Here is the question. Can I run two heaters off on one 30 or 40 amp relay? or should I use two relays with one pressure sensor, switch, etc?
Keep in mine that my bottles are hooked together with a Y so the pressure on one is the same on the other.
Thanks.
Thanks.
Re: Relay and wiring question - electrical guys help please. Nitrous bottle heater x2. (AggAccord03
Wire each heater to have it's own relay.
Just split the signal wire from the switch itself. (Instead of 1 wire going back send 2)
Make sense?
Make sense?
longshot
11-19-2008 11:37 PM
tub_sephiroth
05-09-2007 07:35 PM
