recently turbo d16y8 but has no boost
whats up i just turboed a d16y8 in my 95 civic but i has no boost. what would i check to fix the problem. wastgate line is ran to the back of my edelbrock manifold and the other vacuum lines are ran to fpr vacuum line. any ideas or anything would be appreciated..
Hey man, Im planning on turbocharging my pretty much stock d16y8 over the summer but still trying to find out what all I will be needing and trying to get some ideas on what setup to go with. I was thinking of getting the regular 2000 buck greddy turbo kit and buy the rest of the kit off ebay so. Trying to go with that kit so I dont have to tune with a hondata or anything, just stick to the e-manage that comes with it, I have a budget of 3500 bucks. But what do you suggest? What all do you have in your d16y8? Thanx man this will be highly appreciated!!!
Location: The Village Hidden in the Leaves: Seattle, WA
maybe a little bit more info on the setup? i'm guessing you're running an external wastegate. make sure you have the firering in and have the vac line hooked up to the correct port. post a picture if you can.
Re: (danny_civic97)
its a d16y8 w/ edelbrock performer x manifold w/ secondary fuel rail bbk 62mm TB aem fuel rail dhracing fpr dsm 450 injectors obx fmu walboro 255 fuel pump vafc msd 6a box msd wires msd blaster coil msd cap lightweight flywheel and crank pulley hf manifold adapter plate small 16g w/internal wastegate 2.5" downpipe dump tube blitz bov frount mount p28 ecu and that should pretty much do it
Re: (RipSiTurboHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RipSiTurboHatch »</TD></TR><TR><TD CLASS="quote">its a d16y8 w/ edelbrock performer x manifold w/ secondary fuel rail bbk 62mm TB aem fuel rail dhracing fpr dsm 450 injectors obx fmu walboro 255 fuel pump vafc msd 6a box msd wires msd blaster coil msd cap lightweight flywheel and crank pulley hf manifold adapter plate small 16g w/internal wastegate 2.5" downpipe dump tube blitz bov frount mount p28 ecu and that should pretty much do it </TD></TR></TABLE>
i'm not sure how the performer x manifold is laid out, but if it's anything like the victor x, there should be enough ports on the back of it for anything that needs to read vacuum.
here is my old victor x manifold
i had one port for the brake booster, one port for boost gauge, one port for wastegate, one port for blow off valve, and i think one port for fmu or whatever else. i forgot. haha
make sure all your clamps for your intercooler piping are tight and you have no boost leaks. no vac lines with holes/rips either
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danny_civic97 »</TD></TR><TR><TD CLASS="quote">Oh and one more thing, I really wanna be able to keep my ac and power steering...I live way down south in Texas so yeah, things can get a bit warm down here </TD></TR></TABLE>
why are you thread jacking? search or make your own thread
Re: recently turbo d16y8 but has no boost (RipSiTurboHatch)
If the tune is to far off, the turbo will be incapable of making boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danny_civic97 »</TD></TR><TR><TD CLASS="quote">Hey man, Im planning on turbocharging my pretty much stock d16y8 over the summer but still trying to find out what all I will be needing and trying to get some ideas on what setup to go with. I was thinking of getting the regular 2000 buck greddy turbo kit and buy the rest of the kit off ebay so. Trying to go with that kit so I dont have to tune with a hondata or anything, just stick to the e-manage that comes with it, I have a budget of 3500 bucks. But what do you suggest? What all do you have in your d16y8? Thanx man this will be highly appreciated!!!</TD></TR></TABLE> https://honda-tech.com/zerothread/1643764
