rc inj. don't fit?
rc inj. don't fit?
my cuz got some new RC 440 for a b18c and they don't fit the stock clips. do they make direct fit or will the RC's clip-on be needed?
Re: rc inj. don't fit? (teddy_dc2)
He must be using the harness from the car unless he's right hand drive and used the JDM harness. Just take the clips that are on the JDM harness and wire them to your harness
it seems the stock wires were cut and reconnected to the injectors. he's trying to make them fit by cutting the inside plug bigger, bad ideal?
Re: rc inj. don't fit? (b16adx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16adx »</TD></TR><TR><TD CLASS="quote">He must be using the harness from the car unless he's right hand drive and used the JDM harness. Just take the clips that are on the JDM harness and wire them to your harness </TD></TR></TABLE>
the JDM harness is the same as a USDM. its not on the other side of the engine bay.
Re: rc inj. don't fit? (CoreyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR »</TD></TR><TR><TD CLASS="quote">
the JDM harness is the same as a USDM. its not on the other side of the engine bay.</TD></TR></TABLE>
If its a JDM harness the plugs are on opposite sides due to it being RHD.....I take it youve never seen a JDM and a USDM harness together.....Have you ever done a JDM swap before
SEARCH
SEARCH
Go to a junk yard and get OBD1 clips from pretty much any honda. Then Cut the injector wires and wire the new one up. Done like 20 bucks maybe less. Take the injectors with you so you can check.
Wow and I thought I was a noob to bad information
Re: rc inj. don't fit? (slowsolGA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowsolGA »</TD></TR><TR><TD CLASS="quote">
Wow and I thought I was a noob to bad information</TD></TR></TABLE>
you ARE a noob, idiot. i have TWO JDM harness sitting in my garage and both were imstalled in USDM cars. how many do you have? exactly, NONE.
You must have the ONLY one thats exactly the same....haha you got two usdm harnesses sitting there or someone modified them and sold them to u as usdm and you dont even know it
https://honda-tech.com/zerothread?id=441892
https://honda-tech.com/zerothread?id=487526
https://honda-tech.com/zerothread?id=1431630
https://honda-tech.com/zerothread?id=759200
https://honda-tech.com/zerothread?id=1370956
https://honda-tech.com/zerothread?id=1282927
https://honda-tech.com/zerothread?id=475476
https://honda-tech.com/zerothread?id=187414
So your saying you plug and play with JDM harnesses? That shows youve never done a swap before
wtf?!
wtf?!
EvenStar
Audio / Security / Video
12-14-2006 03:26 PM
95excoupe
11-14-2004 10:03 PM
