Rc 440cc's with stock Ecu and JRSC ?
I have a skunk2 racing ecu right now and will install a JRSC
would the 440's work with this ecu or can I use a different program? Im going hondata soon but right now Im going to settle for 6psi and stock fuel pump would this setup work for the meantime? thanks
New User
Re: Rc 440cc's with stock Ecu and JRSC ? (Boosted Ego)
Do not run that skunk2 program with boost. The ignition timing values are WAY too aggressive for a supercharged application, and that program was written with n/a cars in mind. I have witnessed two different individuals locally destroy their motors with this program, one was s/c, the other was turbo. Put the stock ECU in with stock injectors and the JR FMU and assorted hacks until you get the Hondata unit, then install the 440's and Hondata.
Re: Rc 440cc's with stock Ecu and JRSC ? (VaporTrail)
great thanks for the heads up!, I have a JDM 95 B18c motor could I swap my ecu with my friends 95 USDM Gsr?
or get a stock ecu program?
1 Post
Re: Rc 440cc's with stock Ecu and JRSC ? (metal-x)
i dont think it would matter if u get lets say a hondata....im guessing the maps are diffrent between USDM and JDM..but once hondata is in...your going to have a whole new map. well sorta
trick_db
04-30-2006 09:10 AM
