rc 310 injectors leaking. help !
i finally installed the greddy kit this sunday and had the car running well for about 1 day then the check engine light goes on when my gas was near empty.
Later on that night while warming it up i smell gas and find out the injector closest to the distributor is leaking from the top since the o-ring was cracked. I replace it and everything was fine again for 1 more day. Then today check engine goes on and the same injectors starts leaking again.
I can keep replacing the O-rings but what is causing it to crack again? And yes i lubed them up with a little bit of grease
thanks alot guys!
thanks alot guys!
Re: rc 310 injectors leaking. help ! (whteteg8901)
Sometimes there are spacers you have to take out of the intake plenum to get the injectors to seal/fit right...Look in to that a little..It may be your problem..
fernruffryders
10-07-2005 12:50 PM
