ran my car last night, heres the times, turbo LS
anyways, heres the setup
96 civic ex coupe
96 Ls motor, bone stock with 135k miles
clutch, 94 del sol b16 trans
full ignition msd
drag 3 kit t3t4 63 trim
3 inch exhaust
12-1 fmu, intank pump
stock injectors
9-10 psi, no tuning at all
i ran 3 runs, heres my best time, i ran on slicks, but wasnt really launching it that hard, didnt really feel like towing it home
R/T .827
60' 2.128
330' 5.785
1/8 8.667
mph 85.90
1000' 11.135
1/4 13.240
mph 106.87
i dont think thats that bad for a heavy *** EK
96 civic ex coupe
full ignition msd
3 inch exhaust
stock injectors
R/T .827
60' 2.128
330' 5.785
1/8 8.667
mph 85.90
1000' 11.135
1/4 13.240
mph 106.87
Re: ran my car last night, heres the times, turbo LS (hybridb18)
looks nice to me for the fuel management your using and no tuning...
2.1 60's are nice.. get a 1.8-1.9 with slicks and see 12's
Re: ran my car last night, heres the times, turbo LS (phiberoptik)
yea, i think i need to get a gsr trans or something, i was well into 5th gear at like 5000 rpm when i crossed the line. heehehehe, it would probabally save be some time not shifting into 5th
good times!! im gonna do turbo ls in my eg hatch. i was gonna keep the internals stock and use a gsr lsd trans. i was also thinking about a greddy kit, does that setup sound all right?
Re: (hybridcoupe97)
run some 91+ gas and set the timing back to stock launch a little harder and youll go easy 12s. You dont need to pull timing on a Ls unless you boost high.
Re: (JdmRiceMonster)
i wasnt really launching it, it was more like slipping the clutch from like 3-4k. i wasnt really trying to destroy my transmission. In the past every time i took slicks to the track, my car had to be towed home(stock honda diffs are weak).
Anyways if i pulled a 1.8-1.9 60 ft, thats a easy 12 second run
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridb18 »</TD></TR><TR><TD CLASS="quote">yea, i think i need to get a gsr trans or something, i was well into 5th gear at like 5000 rpm when i crossed the line. heehehehe, it would probabally save be some time not shifting into 5th</TD></TR></TABLE>
if im not mistaken arent gsr trannies geared shorter and closer, with a big final drive gear?
Re: ran my car last night, heres the times, turbo LS (greekspeed)
ummm, gsr trannies are geared longer than a b16 trans(i have a b16 trans)
isnt that kinda dangerous to run that high of a fuel pressure? 12 to 1 fmu at 10 psi = 120 psi plus you stock which is probably about 40psi....thats like 160 psi of fuel pressure in you lines and through stock injectors at 10psi. Thats bad isnt it?
Re: ran my car last night, heres the times, turbo LS (BoostedD15B7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedD15B7 »</TD></TR><TR><TD CLASS="quote">isnt that kinda dangerous to run that high of a fuel pressure? 12 to 1 fmu at 10 psi = 120 psi plus you stock which is probably about 40psi....thats like 160 psi of fuel pressure in you lines and through stock injectors at 10psi. Thats bad isnt it?</TD></TR></TABLE>
Yea, that isnt really that good to do that, im working on getting some 450cc dsm's and an afc with a lower ratio fmu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greekspeed »</TD></TR><TR><TD CLASS="quote">
if im not mistaken arent gsr trannies geared shorter and closer, with a big final drive gear?</TD></TR></TABLE> The LS trans has the long 5th gear.
leadfoot78
04-17-2005 10:51 AM
B18PoweredCivic
04-24-2003 09:43 AM
