Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   radiator problem.... (https://honda-tech.com/forums/forced-induction-16/radiator-problem-931309/)
ATS*Mark Jul 19, 2004 02:59 PM
i have an aluminum radiator and the nipple that hooks up to the overflow hose came off , ive tried jb weld numberous times and it doesnt hold for that long , can i soldier it???? i was gonna try that and see if it works . what are your thoughts?
DaX Jul 19, 2004 03:18 PM
Who makes it? No warranty?
Maybe try drilling out the location where it goes and tapping it 1/4" NPT, then using a pipe to hose barb fitting.
ATS*Mark Jul 19, 2004 03:59 PM
Re: (DaX)
its got a warrenty but im trying it for quick fixes because its my daily driver......
ek9vboi2 Jul 19, 2004 04:03 PM
Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX &raquo;</TD></TR><TR><TD CLASS="quote">Who makes it? No warranty?
Maybe try drilling out the location where it goes and tapping it 1/4" NPT, then using a pipe to hose barb fitting.</TD></TR></TABLE>
Very smart idea. Why dont you find ur old rad. and use it while the alum. is being fixed?
ATS*Mark Jul 19, 2004 08:16 PM
Re: (ek9vboi2)
cause its at my moms house , and im at my house 3 hours away
pngfolife Jul 19, 2004 11:03 PM
Re: (Hella_JDM)
JB won't hold it since they use a ferrous metal base. The aluminum expands twice as much when hot and the JB weld just flakes off. You can probably use silver solder since it melts at a slightly higher temp than lead solder. I don't think that the radiator would get hot enough the melt the solder anyways. It's worth a try!
